9417 SD - Dies instantly after startup when cold
Car will not stay running after cold start. It starts up very fast without giving it any throttle. The car fights me to stay running after start up with throttle. Once i'm able to get the car finally warmed up it idles fine. TPS is 13.3% and 1000rpm at idle when warm. Fuel pressure and battery voltage are in check.
Car is all stock except for E85, SD, Walbro 255 and 3" exhaust.
I am wondering if this is something related to the IAC. When the car is warm, it revs up and returns to 1000rpm fine.
Could be, have you adjusted the BISS using evoscan? Are the injectors dialed in? If not stock what kind are they and what are your settings for them? Do you have a wideband, if so what is it doing when it dies. If you haven't already do a boost leak test, paying extra attention to the throttle body. The O-ring on my biss was degraded and it was causing me problems until I tracked it down.
They are stock injectors. AFR looks pretty decent, a little on the lean side but shouldn't cause it stalling.
I'll do a leak check as well. No obvious loud leaks from listening by ear with it running.
I have not adjusted the BISS using evoscan, only by warming up the car and then adjusting the biss to get my desired RPM at full temp. After I adjusted the biss and set the tps sensor to 13.3%. I will use evoscan w/ the speed adj. screw mode next and see how that works out.
bonesaw52
Apr 15, 2011 12:12 PM
