ID 1050X - Issue
ID 1050X - Issue
Hi guys,
Facing an issue with 1050X. the car tends to stall on tip in and goes full lean and comes back.
I can hear a slight miss fire some times not regularly. Any one experienced this condition ?
Base fuel pressure is set to 40 PSI.
Why is the base pressure 40 and not the standard 43.5?
To me, this sounds like a tuning thing though and not an issue with the injectors.
I have checked it at 40, 42, 43, 48 and 50 Psi but behavior remains the same.
I assume they are getting into non linear area in lower pulse width requests.
I can only say that I personally run the ID1700x and don't seem to have the issue you are.
I'd probably set the fuel pressure to the standard 43.5 and see if your tuner has any ideas assuming you aren't tuning it yourself lol.
Evo8Emperor
16
Apr 4, 2008 09:27 AM
CELL
Mar 27, 2007 08:46 PM
