ECU Flash Missing xml File
Hi everyone, i am pretty new to using ecuflash and i am running into an issue when i try to load in a rom. I have a 93 and e85 map that both show "unkown rom image" when i open them up in the program. From the research i have done on here, it sounds like i am missing an xml file that is needed to read these. I've reached out to the tuners but no luck so i was hoping someone on here would be able to try and see if they have an xml on their system that is able to view these. The car is a 2003 Evo 8 and I have tried the tephra 94170715.xml , but that does not work. Any help or advice is much appreciated!
Hachi Evo (Aug 12, 2024)
Razet
Sep 11, 2019 01:20 AM
