ECUFlash / Evoscan / Mitsulogger Questions
#1203
i have a simple question,i have evoscan on my old laptop but i want evoscan on my new laptop,but i cant find the download thing on their website,how do i download it?
#1207
Ive been trying to DL mitsu logger here, as I'm tired of fighting with the poor real time data graphing in EvoScan.
However, every time i click the link on your website the page just reloads and nothing happens!
Help!
Help!
#1208
Thank you for pointing that out. I made some upgrades and other changes and some links/images had the old location.
It should be fixed now.
Keep in mind that version of Mitsulogger is for the openport 1.3 cables (or any other VAG-COM compatible FTDI Chipset based cable)
#1209
So its no good with 2.0 cables? darn....
What i hope Mitsu logger does, that EvoScan doesnt is all dealing with the chart function. When you start a log and open the real time chart, the left / starting side of the x-axis fix's its self in time. then the rite side just auto fits as the log grows so over a long datalog the graph is absolute junk to look at.
if the thing would just scroll the last 20-30sec of data, itd be far more useable.
can this be changed in EvoScan? How does Mitsulogger do it?
#1211
[14:05:45.341] EcuFlash Version 1.43.3252
[14:05:45.341] OS Version Windows 7
[14:05:45.341] Qt Version 4.6.2
[14:05:45.341] 62 memory models read.
[14:05:45.341] scanning for metadata models in C:/Program Files (x86)/OpenECU/EcuFlash/rommetadata
[14:05:45.513] 356 ROM metadata models scanned.
[14:05:45.513] checksum module "subarudbw" loaded.
[14:05:45.513] checksum module "mitsucan" loaded.
[14:05:45.513] checksum module "mitsuh8" loaded.
[14:05:45.513] patch module "Subaru CAN Enhanced RAM Parameter Logging" loaded.
[14:05:45.513] patch module "Mitsu CAN RAM Parameter Logging" loaded.
[14:05:45.513] flashing tool "wrx02" loaded.
[14:05:45.513] flashing tool "wrx04" loaded.
[14:05:45.513] flashing tool "sti04" loaded.
[14:05:45.513] flashing tool "sti05" loaded.
[14:05:45.513] flashing tool "mitsukernel" loaded.
[14:05:45.513] flashing tool "mitsukernelocp" loaded.
[14:05:45.513] flashing tool "mitsubootloader" loaded.
[14:05:45.513] flashing tool "shbootmode" loaded.
[14:05:45.513] flashing tool "shaudmode" loaded.
[14:05:45.513] flashing tool "subarucan" loaded.
[14:05:45.513] flashing tool "subarucand" loaded.
[14:05:45.513] flashing tool "mitsucan" loaded.
[14:05:57.695] Using interface OpenPort 1.3 Mitsubishi EVOSCAN1d468f6d500000000000000000000000000000000
[14:05:57.695] interface close
[14:05:57.710] unable to connect to vehicle interface.
EvoScan 2.9 works fine, but I had to change to MUTIII & set the baud rate to 62500. Searched for but can't find a way or need to set the same under ECUFlash. ECU is not locked. I can use EVOScan to read/verify ECU flash. Win7 control panel says 1.3 cable is working fine. Tried re-installing ECUFlash to no avail. Any suggestions?
#1213
ecuflash problems
hi....
I have two problems with ecu flash and my tuning stay freeze.
First the pop up window with vehicle type is empty.
Second I download the ecu image with other laptop but when i open the image with ecu flash some values are 'I think' are not correct. Take a look on rpm and load engine values.
RPM: 395, 461, 2559.., 1364.., 2559...,1406..., 105, 0, 39,78,117,156,195,234,273.
LOAD: 41,43,47,50,53,56,59,62,66,69,72,74,78,80,204...,1 09...,204...,112...
ecu id: 96260007
Thanks Haris.
ecu id: 96260007
Thanks Haris.
#1215
hi....
First the pop up window with vehicle type is empty when trying to log ecu, by ecuflash.
Second I download the ecu image with other laptop but when i open the image with ecu flash some values 'I think' are not correct. Take a look on rpm and load engine values.
ecu id: 96260007
https://www.evolutionm.net/forums/at...elmap-copy.jpg
ecu id: 96260007
