need help: new xml files for upcoming ECUFlash release
#153
hell id be happy if ecuflash just worked! there seams to be no way in hell i can get it to display my rom keeps on saying "unknown ROM image- ecuflash could not recognize this ROM image using any of the current definitions" if you know how to help visit my thread https://www.evolutionm.net/forums/sh...d.php?t=383272 all i want to do is be able to view and play around to learn it, alternatively is there a similar programme to ecuflash that works?
thanks
thanks
#154
20081101v2 xmls
I made several more revisions to the 88590015 xml file and evo9base xml:
1) Now has correct target idle tables
2) jcsbanks knock tables
3) Slight revision to table names in "turbo dual boost solenoid" tables
If no one has any substantiative objections, this will be the final for the next release of ECUFlash. I wanted to get the ISCV tables fixed up, but I'm burned out for now, so I'll save that for another ECUFlash release down the road.
tephra and al\lupo, if you could convert to your ROMs, then I'll submit the package to Colby.
Would be great if someone could step up to do the Evo 8s. I'd do it, but I'm strapped for time as it is.
#155
#157
Attached 88840016 and 88840017 for EDM.
A question abot Idle tables: did you note that "Target minimum idle" and "Desired ISCV intial step position with AC off-Neutral" does have the same address (so they are the same table)?
#159
