Air Density Compensation Table
Just posting some info on the air density compensation table that is used to calc airflow rate and temp/density compensated load. Here is the ECUFlash definition for the 88590015 ROM:
The table values and a plot of the values are shown below. A curve fit to the data in the plot shows that the density compensation follows a 1/T correlation indicating that the compensation values follow the ideal gas law (PV=nkT). The fact that it follows the ideal gas law means that this table is not what I could consider to be an "adjustable" table. Instead, its a baseline compensation, and I believe that there are other tables used to tweak the air density compensation for fuel control.
Here are the table values:
![](https://www.evolutionm.net/forums/attachments/ecu-flash/124317-air-density-compensation-table-air-density-comp-table.gif)
Here a plot of the values showing a 1/T relationship between the compensation value and air temperature:
Code:
<scaling name="AirDensComp" units="Air Density Correction" toexpr="x/129" frexpr="x/129" format="%.3f" min="0" max="2" inc="0.01" storagetype="uint8" endian="big"/> <table name="Air Density Compensation" category="Misc" address="30fe" type="2D" level="2" scaling="AirDensComp"> <table name="MAF Air Temp" address="714a" type="Y Axis" elements="8" scaling="Temp"/> </table>
![](https://www.evolutionm.net/forums/attachments/ecu-flash/124316-air-density-compensation-table-air-density-comp-graph.gif)
For 96940011:
As MrFred stated, it's just a table that the ROM uses for a lookup for a PV=nRT calculation. There are few lookup tables similar to this that I remember mrfred coming across before. You should never have to change it, since it's basically just a lookup for a calculation.
Code:
<scaling name="AirDensComp" units="Air Density Correction" toexpr="x/129" frexpr="x/129" format="%.3f" min="0" max="2" inc="0.01" storagetype="uint8" endian="big"/> <table name="Air Density Compensation" category="Misc" address="2dc2" type="2D" level="2" scaling="AirDensComp"> <table name="MAF Air Temp" address="5ec8" type="Y Axis" elements="8" scaling="Temp"/> </table>
air, airdensity, compensation, density, evo, flow, fuel, grauge, racing, relationship, relative, table, tables, temp
