Advanced fuel control options
#92
I just had other tables that were found previously as well that initially were listed as start up related. Good to know when I was looking at the dissassembly I wasn't loosing my mind though as I had came up with basically what you listed above and thus the reason I took them down.
I'm beginning to see that there are a lot of tables floating around on this site that I have spent a great deal of time tracking down that are not right. Oh well, I think my future method will be that any time I want to mess with a table that may not be well known, I'll be double checking that the table is defined correctly through dissassembly first (at least size, location and in the right routine anyway).
#93
BTW, how are warm starts with your ID1000s right now?
There are quite a few guesswork tables out there, especially for fueling where there are such a large number of factors that play a role in the final pulse width. If you want, I can give you a well disassembled 9653 disassem to work from. I haven't inserted very many comments, but all the hex has been converted to either code or data. Of course you are also welcome to have a copy of my 8859 disassem. I'd venture to guess that its probably the most commented Evo disassem out there. PM me if you are interested.
#94
pm's are full, email sent to the email in your signature
I have reverted back to an older ROM for a couple different reasons. Mostly because I've been trying out a few different methods to tune the speed density tables and trying to get a feel for what offers the best driveability and tuning flexibility. I ran across a bad table or two though that had some detrimental effects on how the car ran and I'm not exactly sure the first date I started using the bad tables. As such, I'm back to lousy start ups but a car that runs well enough and starts reliably (albeit after numerous cranks).
#98
Did you notice if putting the car in open loop through the periphery bits drops this calculation out?
When switching back and forth between open and closed loop testing things, I've been resetting the ECU to make sure it clears these values out. Just wondering if that's needed or not.
#99
#104
Is this the correct table for 9653XXX6
Code:
<table name="Closed Loop - LT Trim Control" address="35e5" category="Closed Loop Control" type="2D" level="2" scaling="AirFlow Hz"> <table name="Condition" type="Static Y Axis" elements="4"> <data>Low -> Mid</data> <data>Mid -> Low</data> <data>Mid -> High</data> <data>High -> Mid</data> </table> </table>
