Dyno numbers for gsc s1`s AMS tune (post your gsc s1 dyno # here
#32
Worry not
![Smilie](https://www.evolutionm.net/forums/images/smilies/smile.gif)
#34
https://www.evolutionm.net/forums/ev...sh-racing.html
Worry not
This was straight 92, not meth. 93 and meth should eclipse this pretty easy.
Worry not
FP Red 80mm
PPI Coated/Ported Exhaust Manifold
Ported Megan o2 Housing
GSC S1 Cams
FIC 880cc Injectors
Walbro 255
ETS 3.5" FMIC w/ Piping
AMS TBE (Catless)
on 92 Oct=
421/408
So^^^+
-93oct
-Meth (Aquamist hsf-6)
-Ported Intake Manifold
-65mm throttle body
BUT i'm also running a high flow cat....
I'd like to see 470 on Ivey's dyno.
It's going to be painful getting that close to 500 and not breaking it
![Crap](https://www.evolutionm.net/forums/images/smilies/crap.gif)
![Thumb Down](https://www.evolutionm.net/forums/images/smilies/icon13.gif)
I wonder how much i'm giving up from a GSC S2??
#36
me? because I've had them for about a year now and they seemed to be the best option for a stock turboed car. I've said it before: although i have no experience with other cam options, I really really like the S1. They drive great and seem to make great power.
I'm just worried they're too mild for my new setup. We'll see tomorrow!!
![Thumb Up](https://www.evolutionm.net/forums/images/smilies/icon14.gif)
#37
here are my s1 results- 353/338
mods are,
05 evo 8 mr
stock turbo
91 octane
mbc@22psi
ported stainless o2 housing
no cat, megan downpipe, hks hi power
injen licp, uicp, intake
unknown 3.5" ic
ix diverter
1 step colder plugs
4WS TUNE FTW
mods are,
05 evo 8 mr
stock turbo
91 octane
mbc@22psi
unknown 3.5" ic
ix diverter
1 step colder plugs
4WS TUNE FTW
#40
Our customer Thaine has been an avid road racer since he started coming into the shop year before last. His 05 RS has been build deliberately staged so that each time he takes out he can see the differences and if the changes are helping or hurting.
Last year the car on his normal torco/92 mix for the track put out high 320s on the stock cams. A set of S1s yielded a grand total of 366 at 26psi (his max for road racing). This off season, Thaine wanted to mix it up so he added a Red, ID1000s, ported the exhaust manifold, and switched to SD.
With the new found injector I was able to keep the car a little richer for those 20 min lap sessions and to stave off heatsoak induced knock. Here are the results-
![](http://i275.photobucket.com/albums/jj311/LucasEnglish/EVO%208%20Dyno%20folder/stock2redThaine.jpg)
![](http://i275.photobucket.com/albums/jj311/LucasEnglish/EVO%208%20Dyno%20folder/stock2redThaineUncorrected.jpg)
and the logs-
and the logs-
This plot shows my car with stock turbo and S1s then with FP-red and S1s. There could be more power to be had but we need to see how this copes with track days 1st
#41
GSC S2 cams were installed in my car before I bought it. The only other mods were intake, TBE, and MBC. I spoke to CBRD because I was wondering if the S2's were overkill for my setup. I was told that they don't even reccomend the S1's simply because they have seen a bigger gain from the S2's even on a stock car.
#42
with the mivec adjustments on the stock cams, we dont see big increases with the s1's... the s2's work excellent..
evo 8 is a different story, s1's show great gains.
cb
#44
This is for CBRD...At what RPM will an EVO 8 start spooling up with S1 and stock turbo? What other boltons if any will help the spool with this set up? How does an HKS 264 or 272 compare in terms of power and spool? thanks guys!
