HB Speed/ Cobb Tuning EvoX
#31
It was only about a month ago that the first Evo X version of ECUFlash went to beta testers. Thanks to one particular individual, quite a bit of progress has been made in that one month. I would guess that you've browsed through some of the xml files that have been posted. Much more has been found in recent weeks, but this kind of thing could go on forever so at some point, everything that is fully defined needs to be cleaned up and put into the first release. The first release will have the typical tables that people expect to see. I imagine that for the next couple years, each update to ECUFlash will include more tables for the X.
I have tuned my X with both Cobb and OS.
The XML i have i haven't seen posted here but in another forum
![Wink](https://www.evolutionm.net/forums/images/smilies/wink.gif)
#37
Ive been testing and testing and testing, i have tuned over 15 X's with ecuflash
My car has a Gt30R and 800 Cc inj. Several of these cars have been in competition so i can see how the X does being beat HARD.
Ive had to combat TQ limiters, Airflow Limiters and all sorts of interesting things that im trying to figure it all out to let the "powers that be" know what is up.
If you dont like that i can definitely stop trying to help out
Im trying to work around things that i haven't posted about. Im also making maps for different intakes and injectors to share with the community.
Ecuflash is missing some things that Cobb has.
I use Ecuflash and Cobb every day, as im sure GST does as well.
I took down the charts i put up in the os forum since you seemed to have such an issue with it.
#44
Im assuming the only way to keep from voiding the warranty is taking your factory ecu out, and swapping it with another factory ecu to tune on, then swapping back the factory ecu when visiting the dealer?
Or am I way out in left field on this one?
