HB Speed/ Cobb Tuning EvoX
Old Dec 16, 2008 | 10:21 PM
  #61
triguy's Avatar
Thanks Jon. How's the T1R exhaust for someone who's looking for a performance exhaust that isn't freakin loud? It is touted as quiet as stock when cruising with a bit more growl.
Old Dec 16, 2008 | 11:05 PM
  #62
HB Speed's Avatar
i think there are 2 great options
the T1R or the MXP. i have installed/ Tuned both and i like them. neither is that loud
I think im gonna make some "grapefruit shooter deletes"
IE: Remove the huge tip and weld on regular pipe for the "stealth" factor, who knows..
Old Dec 16, 2008 | 11:42 PM
  #63
spdracerut's Avatar
Originally Posted by HB Speed
yea
im gonna do a PILL and see what happens on this sucker
ive got a few more to test so i hope to make more power soon!
Ya know.... I'm not really sure how much more upgrading the pill will do. I'd guess that you're near the max flow of the stock turbo.
Old Dec 16, 2008 | 11:48 PM
  #64
HB Speed's Avatar
really?
cause i made more power on 94 today too
i just left the chart @ the shop by accident....
Old Dec 16, 2008 | 11:52 PM
  #65
spdracerut's Avatar
Hmm.... what was the difference in mass flow rate? I'd gather that you added a fair amount more timing and maybe leaned it out a bit.
I'd love to see what the new Garrett turbos will do on pump though!
Old Dec 16, 2008 | 11:56 PM
  #66
HB Speed's Avatar
The Maf rate went up quite a bit ( yea i logged it)
The AFR was leaned out .5 afr and added 2-3 degrees.
I wasn't pushing it to the limit.
Ive had a gt30R on my car... it was great, spooled so fast i could surge it if i so chose to. had a leaky oil feed so i removed it. Ill have another soon.....
It was fun 22 psi was over 380 on pump (ca pisswater 91) very safely
Old Dec 17, 2008 | 12:14 AM
  #67
RazorLab's Avatar
I've logged 286 g/sec @ 7500rpm @ 16.3 psi and 191 load with the stock boost system maxed out.
Then with upgrading the boost assembly I've logged 302 g/sec at 7500rpm @ 18.3psi and 203 load
So yes indeed it is flowing more.
Old Dec 17, 2008 | 12:24 AM
  #68
sspaladin28's Avatar
Excellent. Its nice to have an ecuflash option in socal
Old Dec 17, 2008 | 01:30 AM
  #69
Massappeal's Avatar
Wheee!!!
Old Dec 17, 2008 | 06:19 AM
  #70
dcasandman's Avatar
^^^Sweet now I really cant wait till Thursday!!
Old Dec 17, 2008 | 09:28 AM
  #71
ETS Michael's Avatar
Nice Job Man. Great Results!
Old Dec 17, 2008 | 09:33 AM
  #72
spdracerut's Avatar
The Garrett drop-in 3071 and 3076 should be out sometime around spring
I was just thinking with the upgraded actuator, the stock boost setup would be able to max out the stock turbo. I guess not!
Razorlab, stick a LVDT on the actuator to see when it's moving
Old Dec 17, 2008 | 02:03 PM
  #73
Papi4baby's Avatar
You guys are so lucky when it comes to that. There's quite a few of them.
But was this ECUflash or AP?
I guess you will be on the 350's too sandman,
Old Dec 17, 2008 | 04:36 PM
  #74
JayDub514's Avatar
It looks like it was Cobb AP Protuned by none other than Jon himself.
Great, now I have to look around the house to see what I can sell to fund this addiction.
Old Dec 17, 2008 | 04:53 PM
  #75
jayevo23's Avatar
what were the gains with the mxp?
