35R dyno thread
#32
car finally came home. i dont have the dyno sheet yet, but i will soon. unfortunatly my meth kit leaked from every little crack in the system so i had to get tuned for straight pump gas (93) untill my new pump comes in the mail.
car made 463 @ 27 psi 93 oct @ 6700 rpm
***i was tuning the car so i didnt wrap it to rev limiter, but the line kept going straightt up so its probably higher***
stock bottom end
kelford 272s
peakboost tubular manifold (intended for 37r)
precision 1000cc inj
walbro 255
ets front mount
and other various bolt ons
overall im extreammmly happy with 463 on straight pump.. i cant wait till im running 32 lbs on meth!!
stock bottom end
kelford 272s
walbro 255
ets front mount
Very nice numbers. Im really looking into a gt35r kit right now and I just dont know if I want to use a stock block or build it. I would be happy with your numbers, I just want it to be a reliable car.
#33
Got pretty much the same set up as...
Originally Posted by datrip
I got an interesting one for all. Mods for power are as follows:
- Peakboost GT3582R Turbo w/tubular manifold
- Tial 44mm Wastegate (with spring for 11psi+)
- PWR Intercooler
- PWR Radiator
- GSC 272 Cams
- ARP Headstuds
- 1000cc Injectors
- AEM EMS
- Custom IC Piping
- Walbro Fuel Pump
- Fidanza Cam Gears
-HKS Boost Controller
I was on a Dyno Dynamics and got 351whp @22 psi... 91 pump gas
but then the car wasn't fully "tuned" think it was my 3rd run while setting the boost controller.
AF was all over and on the lean side..
I wasn't able to complete tuning because i was running lean after 6000. It’s funny since I’m using 1000cc at 48 lbs fuel pressure… injector duty was at 150%!
Going to check the fuel system…. the pump, rail, and injectors are all new... so need to fin the problem 1st.
- PWR Intercooler
- PWR Radiator
- GSC 272 Cams
- ARP Headstuds
- 1000cc Injectors
- AEM EMS
- Custom IC Piping
- Walbro Fuel Pump
- Fidanza Cam Gears
#34
well the guy that tuned my car has the exact same setup as me except his freaking meth pump works.. anyways he commutes too and from work every day 1 hr drive both ways for like a year and has had no issues with anything yet as long as you keep all your scheduled maintence up.
#36
I loved my garret 35r with a .63 exhaust housing. I dont have my dyno sheet copied but 6000 to 8100 rpms it stayed over 500whp. Tuned by shawn ivey i made 514whp on a stock block evo8. This was on full meth at 32 pounds on stock computer.
my setup:
stock block
stock head
stock throttle body
hks 280 cams
ams vsr intake manifold
turbo trix tubular exhaust mani
gt 35r .63 hotside
ets 4inch intercooler and piping kit
snow perfomance alky kit
pte 780cc injectors
BR 3inch turbo back
my setup:
stock block
stock head
stock throttle body
hks 280 cams
gt 35r .63 hotside
pte 780cc injectors
BR 3inch turbo back
#37
Since my last post we made it to the dyno but my tuner had a family emergency and we had to unstrap from the dyno and head back to town. Since then I have upgraded to RC 1200cc injectors, ordered a dual pump setup and went ahead and got 10gal's of C16. The good thing is that this Friday, the 23rd, is our next chance to get back on the dyno and see what she's got. We are going to try a few different MAPs:
(1)Pump
(2)Pump + 100% Meth Inj
(3)C16
(4)C16 + 100% Meth Inj (this one seems pointless but interested to see if any difference from just C16)
Our next biggest fear is going to be the drive train and transmission. Anyone had any luck on a stock tranny & axles/differentials with 500-600whp? I am going to go ahead and get a quote from Shep for a transmission build, as I plan to have this car at the track a good bit this up coming season. The previous owner claimed to have gotten a new transmission while the car was under warranty less than 10k ago, and being that I have not launched the car since I have owned it, I am hoping the tranny is still plenty strong.
(1)Pump
(3)C16
#38
i will post numbers when my build is finished, soon very soon
mods as follow,,
HKS F-CON VPRO (iveytune.com)
HTA 35r turbo kit .63 / tial 44mm v-band / 3in o2
buschur long block stage 3 (head and motor built stage 3)
tial 50mm bov, buschur upper and lower ic pipes
fluidampr (alum)
jun mivec cams
1200cc -1600 inj, not sure which one's yet
buschur double pumper / perrin fuel rail, aeromotive FPR
buschur race FMIC
wilson v2 or ported stocker, not sure yet
ported 65mm throttle body
arp's heads std
buschur turbo back
probably forgetting some things but u guys get the picture, cant wait to get all finished its been done for a while now so ill post up pics and numbers soon
mods as follow,,
fluidampr (alum)
jun mivec cams
buschur race FMIC
arp's heads std
buschur turbo back
#39
mods as follow,,
fluidampr (alum)
jun mivec cams
buschur race FMIC
arp's heads std
buschur turbo back
mods as follow,,
fluidampr (alum)
jun mivec cams
buschur race FMIC
arp's heads std
buschur turbo back
#40
From the things that i have seen threw tuning, the red and a gt35r are similar in power, the red producing better power at higher boost. But the 35r still producing sick power even on low boost and a stock block like alot of evo owners are doing with the red, but with the Red you dont need to change your manifold, LICP, Downpipe, etc. And with the power the Reds are producing theres no need to do a 35r on a stock block with the lag they have ben known to have.
From my past test with the red and some of my expeirience with the 35r's, the red feeds off of meth or race fuel with 30+ psi of boost ran threw it. So my advice to anyone spending the loot on a FP Red, go the extra step and purchase yourself a nice meth kit, or if you have E85 at your hands. Its like using steroids on a human.
The 35r's on the other hand can be thrown on a stock block but have a rediculous amount of turbo-lag. Ive done cars who put down over 520+ wheel hp on a stock block with a 35r but is that going to last a long life time, prolly not. IMO the 35r needs to be on a 2.3 stroker to be ran at full potential.
They classify the FP Red as almost a 32-33r. Which is awsome because you can bolt it to the stock set-up of an evo. Thats why the production and purchase of these turbos is sky rocketing. People throwing on a FP Red (33r) with a good set of 280/272 cams and meth and throw down over 500+ wheel hp on a stock block.
IMO if you DD your evo and want a fast street/strip car, i would go the FP Red route. Of course with the meth and all supporting mods.
If you want to have an Evo as a secondary car, or a weekened warrior.....go the 2.3l stroker route with of course the always famous 35r.
Of course guys this is my knowledge from the dyno and some of my opinions
do how you guys feel
and i hope this helps some
#42
