friends evo 8 got dyno tuned made only 275hp???
Old May 22, 2009 | 11:45 AM
Ct9aGsR's Avatar
It's an 05 sorry guys that i didnt mention that. With my old 03 Evo on those mods plus gsc cams made 332hp on 22.5 psi but yea he should be little more than 300 hp
Old May 22, 2009 | 12:22 PM
mountainturbo's Avatar
Who did the tune? Or is there one?
Old May 22, 2009 | 12:41 PM
DBallz's Avatar
From: South Beach, FL / Miami, FL / Pt. St. Lucie, FL / NYC
Originally Posted by partyboy1122
Must of went to Big AL.
Wow that sounds like hate
Is you buddy sure they tuned his car? No matter where ever your buddy went tell him not to go back. Unless this car has some sort of mechanical issue something smells fishy. Don't know what shops your buddy has in his area but I would suggest going somewhere else if not try Mellon
Old May 22, 2009 | 01:13 PM
zeus1's Avatar
yeah sounds like something is odd. tell your friend to go mellon tuning you will not, i repeat not regret that decision
Old May 22, 2009 | 02:35 PM
project_skyline's Avatar
Its either a mechanical issue/s or a really trashy tune. Either way that power is weak!
I made 315 with a poor tune @ 25 psi with a downpipe, mbc, and 272's.
Old May 22, 2009 | 02:41 PM
griffeyr's Avatar
so who tuned it???
i supposedly had a "TUNE" and it actually was the stock fuel map, with an fp red turbo, but they told me they tuned it
Old May 22, 2009 | 03:21 PM
JohnBradley's Avatar
Stock cams? What year? We have seen a few of the many Evos we have tuned that for now apparent reason require ALOT more timing than what would look right in the map. Typically it seems to be a 2005 issue but I have seen one or 2 03s as well.
Old May 22, 2009 | 07:54 PM
Blitz's Avatar
I put down "only" 290 on AMS's dyno with turboback, drop-in filter, Tru Boost and flash. With a IX. Tell your friend he's not alone.
Old May 22, 2009 | 08:55 PM
staatz's Avatar
Something is def wrong with the car. Hope your mechanical issues get fixed.
Old May 22, 2009 | 10:11 PM
cfdfireman1's Avatar
I have an idea...
there is 2 studs snapped on to the turbo one on manifold to turbo and other one on the o2 dump on the hotside.
...what is wrong. Try fixing what you know may be the problem and try again. Why would you have a car tuned with known issues?
Old May 25, 2009 | 07:27 PM
99civiccoupe's Avatar
Would the broken studs cause the car to lose almost 40whp if it had an exhaust leak? Do you always hear exhaust leaks?
Old May 26, 2009 | 01:56 PM
tryal's Avatar
i have a leak that developed last night about 1030 either from a cracked exh manifold or the gasket must have gone...not sure yet its on the bottom somewhere...but i can hear it very very well... i'd think that if it was a leak causing a significant loss in HP you would probably be able to hear it because i dont even notice that bad loss of power and mine has to be pretty bad due to how loud it is
also with the old blown motor(prior to it popping), a stock 8 turbo and a vishnu xcede tune, my car put down 272 to the wheels on a mustang dyno so something has to be wrong
Old May 26, 2009 | 02:44 PM
MattsT67's Avatar
so true
Damn son somethings wrong. I did 355whp on a mustang with less mods. I have a IX, but still... thats ****TY
Old May 26, 2009 | 08:44 PM
mhgsx's Avatar
I had a blown ex.mani/turbo gasket on my old GSX w/ 16G. The car trapped rougly 4 mph slower, so I'd say ~40 whp.
Old May 26, 2009 | 08:45 PM
YzBrad99's Avatar
must of went to big al.
lolololololololol
