Tune with new setup BR HTA35R
Got my base tune down this past June, I'd still like to work on the tune more and get the trq up about 90-100 ft/lbs. Its a good start for just 91 octane.
Made 439whp 342 ft/lbs TRQ
http://www.youtube.com/watch?v=8xo17...eature=related
Mod list
Buschur Racing HTA35R Turbo
Buschur Racing Ported Exhaust Manifold
Buschur Racing MAF Pipe Kit
Buschur Racing Turbo Back Exhaust
Buschur Racing 3in Downpipe
Buschur Racing Upper I/C Piping
Buschur Racing Lower I/C Piping
Buschur Racing Deluxe Intercooler
Kelford 272 Camshafts
Findaza Cam Gears
ARP Headstuds
Exedy Twin Disc Clutch
AMS SS Clutch Lines
Walbro 255 Fuel Pump
Tial 44mm External Wastegate
HKS Superflow Filter
DW 880cc Injectors
Forge Bypass Valve
Mod list
Findaza Cam Gears
ARP Headstuds
AMS SS Clutch Lines
DW 880cc Injectors
Forge Bypass Valve
Those are avg numbers for that boost on that turbo. I wouldnt be dissapointed with that. Almos the same as my car my with 880s, comp 272s, ams IC etc at 23 psi made almost the exact same numbers.
3-4 psi will probably add 50 whp aslong as the car will take it. Some car seem to take boost better then other cars it seems. Also boost isnt really a measurement of power. Its a restriction of air flow into the engine.
Take into consideration he is running a 35r at 24psi (not really in its effeciency range) along with 91 octane (higher prone to detonation with increased timing)....... Not bad at all on a base tune!!!
Congrats!
Dan
Congrats!
Dan
I know the numbers aren't what the 35r can produce, I am still working on this car. I currently have the Buschur 2.0 pistons and Manley rods but can't install them because I'm in Korea. Also I have to wait for my transfer case and tranny to get back from TRE. I will update this with the new number when I get this done. I will be posting a E85 dyno, and E98 dyno results, hell I might even throw in some meth.
That is all-
That is all-
Jrod@Buschur
11
Mar 17, 2009 12:13 PM
Jrod@Buschur
Nov 10, 2008 06:31 AM
