Highest HP 4g63 engine (from 2007)
#797
Spyros,
AMS recently set the record for 60-130 MPH. They did it in their GTR, in 3.30 seconds.
http://www.2009gtr.com/2011/08/331-s...ecord-for.html
-Bink
-Bink
The fastest timed Gallardo is Bob Helm's UGR SL stage 3 full street trim on Toyo R888, a customers car, at 3.04 verified... I think two people in the car! The black shop car, the Manual Nera, is probably faster but they haven't disclosed any times yet...
I like the clutchless shifts Spyro. Very nice!
#798
Very Good but
Norris's times are better i think 30-130 mile 5,06
Best 0-60mph = 2.4 sec
Best 0-100mph = 4.3 sec
Best 0-150mph = 8.00 sec
Best 30-130mph = 5.06 sec
#799
Kouzman, yes i know gtrs and lambos are very hard opponents for the small 4g63but we will see.
Oz as far i know Norris car is race car not full interior street car.
Also we just test it with pump gas and 14psi only mechanical boost.
#800
That's probably the first Evo I've seen rev to 11k in every gear on the street.
I don't think the needle can keep up with the engine, though. Are you logging these pulls? I bet he's going over 11,000 RPM's in that video!
In any case, that's an unbelievable amount of acceleration for 18PSI.
#801
Spyros, what is your recommendation for making the evo the most efficient possible from the factory?
Extensive head porting, manifold and exhaust manifold /turbo or are there other considerations that have priority? I guess my question is if somebody gave you a stock evo, what would you immediately remove or modify first to make the car do more at less boost like high whp at only 18psi?
Thanks and I look forward to all your products and info
#802
Whoa... I just read the triple plate clutch on your black Evo holds 1299 ft/lbs of torque? How long do you expect it to last? How long would it last on a "normal" 400 lb/ft producing Evo?
#804
thats fast... illest
http://youtu.be/IYaqskg3Wh0?t=3s
Spyros not sure if I've asked this before but what clutch do you typically use in your high hp/ta builds?
#805
was that a HEWLAND godbox geared somewhat like an oem 5 speed, with a OEM shifter with some mods (no short shifter, tall knob, and bushings and lines?). That was the first time I actually saw a proper shifting evo.
ANYWAY, CLARIFY PLEASE!! THANKS IN ADVANCE
#806
is the boost set to 14psi in this vid? 100-200 4.59 is a very good result for 14psi, im sure you will break the world record of the gallardo and R35 times if you set your boost up to 40psi
is your 100-200 time based on the speedo or dbn file? and what is your best 60-130mph time?
#807
We actually currently hold the record for a verified 60-130 time of 3.31 seconds in an Alpha 12 GTR.
Click Here
#808
1 Post
Bink is correct....
Click Here
Click Here
-Bink
#809
Bink is correct....
Click Here
Click Here
