Highest HP 4g63 engine (from 2007)
Old Jan 25, 2012, 02:15 PM
  #1306
tim radley's Avatar
Originally Posted by Erland ***
From 02 or around that the cylinder walls are shorter and these newer blocks can handle over 1000hp if they stock cylinder diameter is kept or only cleaned up.
Erland
WHP or REALHP?
tim radley is offline
Old Jan 25, 2012, 03:56 PM
  #1307
Broham's Avatar
Originally Posted by khmerpimpin
Setups that flow in the 50lbs to 75lbs range and spool fast, without surge. That's where the money is at.
He is spot on with this Spyros. You should see the amount of people who want to keep their upgraded stock components and make power in that range
Broham is offline
Old Jan 25, 2012, 04:06 PM
  #1308
R/TErnie's Avatar
Originally Posted by Extreme Tuners
We had 840hp (680whp) from a stock frame 62mm 11blade design to a 12,5cr engine using VP import.
As comparison from an fpblack we had 540whp stock fuel and 580whp with race fuel at 38psi to a stage 1 engine 11,2cr 2ltr. There was the limit of the black to our dyno.
As i write to previous post we use from above this garrett ATP turbine housing.
ER did 750whp (Dynojet) on an FP Black. Just saying. The ATP turbine housing is horrid... I would prefer a heavily ported stock housing.
If you're going to build a performing stock appearing turbo that makes huge power, you need make a much larger turbine housing. Requirement #1. I know I've seen myself do it.
R/TErnie is offline
Old Jan 25, 2012, 06:26 PM
  #1309
Erland Cox's Avatar
Originally Posted by tim radley
WHP or REALHP?
Engine hp and they don't break at that.
You can be the first one to find the limit.
This one is still alive but we are only at 975 so far.
This is a sleeved block but a stock crank so maybe we will find out where the cranks limit goes.
The VAG coils started misfiring around 900hp so we will change to MSD.
Erland
Attached Thumbnails Highest HP 4g63 engine (from 2007)-bromsning_vit5a-20-7-.jpg
Erland Cox is offline
Old Jan 25, 2012, 06:31 PM
  #1310
Acree's Avatar
Lol.. "vag" coils... anyone? anyone?
-Acree
Acree is offline
Old Jan 25, 2012, 06:50 PM
  #1311
FJF
FJF's Avatar
-Acree
FJF is offline
Old Jan 25, 2012, 06:51 PM
  #1312
Erland Cox's Avatar
VAG coil on plug coils from Audi and VW are cheap and very good coils.
VAG is Volkswagen Audi Group I believe.
They are used by many and on 500cc per cylinder they should be able to handle the cylinder pressure from 300hp/ cylinder.
But with methanol better coils are needed.
Erland
Old Jan 25, 2012, 06:55 PM
  #1313
4g63evoeight's Avatar
a stock frame unit that would flow 70-75lb/min would be MY turbo of choice. if you could stuff an hta86 into a stock frame that would be my kinda setup!!
4g63evoeight is offline
Old Jan 25, 2012, 07:29 PM
  #1314
as horrid as it may be, flyin_banana trapped 144 @39psi.. its obviously working. thats a pretty good mph for a close to full weight, 2L, stock head, etc..
Old Jan 25, 2012, 11:40 PM
  #1315
tim radley's Avatar
-Acree
Yep i thought the same, something fishy about that claim
Old Jan 25, 2012, 11:41 PM
  #1316
tim radley's Avatar
Erland
Had the same problem at bonneville on the skoda - VAG coils. I'll give you details of the new ones via email.
Old Jan 26, 2012, 02:24 AM
  #1317
guzmangjr's Avatar
That's insane power
guzmangjr is offline
  #1318
guzmangjr's Avatar
Bump for a great thread
Old Jan 26, 2012, 05:18 PM
  #1319
kouzman's Avatar
Originally Posted by juanmedina
so what was the 60-130mph?
3.98 sec... My brother bought the magazine
3.49 sec is the 100-200 km...
kouzman is offline
Old Jan 26, 2012, 06:22 PM
  #1320
azinterrider's Avatar
[QUOTE=gr8stevo;9907795]
There is nothing below 3 as formula 1 have 2.5-2.6.
My personal car is showing 2.5sec 100-200km from my data. What type of timing equipment is being used? Maybe this can become a new form of racing here in the US. I would love to smash those times lol.
Is this from 0 to your top speed? Or holding steady at 60 then accelerating?
azinterrider is offline
Quick Reply: Highest HP 4g63 engine (from 2007)
