TS 6265 hawtness @ D&G Motors
Old Sep 28, 2009, 06:24 AM
crcain's Avatar
Good results! 445 on a DD should be about 580 hp at the flywheel.
crcain is offline
Old Sep 28, 2009, 06:31 AM
Ted B's Avatar
425whp with a DD at "1.0" = ~480whp on a Dynojet.
To the original post - I suggest a Synapse BOV.
Ted B is offline
Old Sep 28, 2009, 08:49 AM
X_Evo's Avatar
Originally Posted by evodan2004
nice setup. can i ask what exhaust housing is on the turbo?
I believe that it is 1.06.
X_Evo is offline
kouzman's Avatar
Well with 460whp which according to your calculation I should be around 520awhp DJ, I am trapping 131mph @ 3370lbs with a messed up 3rd...
Let's see the trap and the weight. Then we ll know
At what boost level? The reason I am asking is to compare power difference with my turbo, the fs635. The 62-65 I think is a bigger turbo so maybe it makes more power with less boost.
kouzman is offline
Old Sep 28, 2009, 08:51 AM
X_Evo's Avatar
Originally Posted by nikkadanny
looks good. corrected numbers would of been close to 500..was this on pump?
Yes, this was done on 93 octane.
X_Evo is offline
Old Sep 28, 2009, 08:54 AM
X_Evo's Avatar
Originally Posted by kouzman
Beautiful! How much boost?
It peaks at 26 psi. It doesn't hold it for long because the BOV leaks boost even with the adjustment screw screwed all the way in.
X_Evo is offline
Old Sep 28, 2009, 09:00 AM
X_Evo's Avatar
Originally Posted by EvolutionBoy67
can we get the answer to this please? and also were you got the turbo. Lastly if you were using a TS 6262 how much faster would it spool up?
It was a regular precision 6262, that was converted over to a TS 6265 by Blouch. A TS 6262 would only spool marginally less then a TS 6265 from my understanding.
X_Evo is offline
Old Sep 28, 2009, 05:21 PM
rong.'s Avatar
aps
Mellon is using the APS twin vent on his monster build that makes 700 horse. I wonder how he gets it to hold. My 2 cents in.
rong. is offline
Old Sep 28, 2009, 06:22 PM
EvolutionBoy67's Avatar
Wow so Blouch now offers TS hotsides? okay if the 6262 will only spool marginally less how much more power does the 6265 make than the 6262? Also can we confirm that the hotside is 1.06?
One last question, does Blouch make TS hotsides for the 6765? and if not can they?
EvolutionBoy67 is offline
Old Sep 28, 2009, 08:27 PM
DG Motors's Avatar
Thanks for the comments! I am glad we got your car running in tip top shape.
The blowoff valve is cranked all the way in and will taper upon boost no matter what we do. A forge or even better( aem ems ) and a tial will hold boost excellent with your setup!
I will never forget about our road test when that bend came up a little tooo fast for both of us.
Guys, the graph is also cut off due to the boost tapering so hard than ramping back up...We did all we could to get the graph to pull clean but the darn bov would not cooperate! The car actually made 460whp on our standard 1.0 CF but felt it was past the edge.
This car is an absolute blast! Even though we had a few issues with this custom turbo kit, it was nothing we couldn't get done 100%.
"Patience is the key to success!"
Enjoy Steve!
DG Motors is offline
Old Sep 28, 2009, 08:29 PM
GST Motorsports's Avatar
Something is wrong with that APS then because I have had APS's hold 32psi to 8k.
Did you put some pipe sealer around the adjustment threads?
GST Motorsports is offline
batty200's Avatar
All you need to do is use a t4 divided housing with it machined for a 62/65 turbine. It isnt anything specific to blouch. You can order the turboos this way most likely. I dont think PTE recomends it though.
batty200 is offline
Old Sep 28, 2009, 08:39 PM
DG Motors's Avatar
There is absolutely something wrong with this bov. Most likely the diaphram.
The bov leaked at 5psi with our smoke tester. The adjustment screw is cranked all the way in. More so, there is no recirculation.
Regardless, this car is safe, making great power on our dyno for 93 octane on a bone stock bottom end. At 26psi, with Maryland 93 Octane, it drives smooth as silk on the Fic 1050cc injectors and is plain wicked at WOT plus got him all the way back home with not a single hesitation, blip, or problem.
The car has almost 60,000 orginal miles and is due on a timing belt and water pump soon. After some maintainence is done, we will be pushing the car slightly harder in the near future with some upgraded parts.
I'm pretty sure Steve enjoys how the car feels on just pump gas and almost a 60,000 mile oringal from the factory mistu motor!!!
Enjoy the car and be Safe Steve!
Old Sep 29, 2009, 12:26 PM
murderedevo256's Avatar
nice work and nice shop. Its good to see customer service at its finest
murderedevo256 is offline
Old Sep 29, 2009, 01:32 PM
X_Evo's Avatar
Originally Posted by Creamo3
Something you may want to check on the APS BOV, verify when it is idling that it's not venting by putting your hand in front of it and feeling for air. On mine w/ speed density I had to crank that adjustment screw pretty much flush w/ the top of the BOV. Just a suggestion, good power too
Thanks for the suggestion. I looked and saw that some people are wrapping the adjustment screw in teflon tape and got it to hold boost. I have really liked the APS and I want to keep it so I'll try that out and keep everyone posted.
X_Evo is offline
Quick Reply: TS 6265 hawtness @ D&G Motors
