My FP RED bolton IVEYTUNE
#31
very nice. I have the forge type-rs bov. same one pictured here http://media.photobucket.com/image/f...e/f89c60dc.jpg
I leak tested it to about 40psi and no leakage.
#33
The hole in the block is only part of the problem, the rod can come out and break all kinds of other stuff too. (tcase, for example)
#34
i would not recommend nor say you can run stock block above 500 whp. At that point your on borrowed time before its over. If i were you i would just put a built 2.3 shortblock in there man and call it a day. Help your spool out even more for that sweet evo you have. lol heck if you want once i pull my whole motor your welcome to buy mine and do it up i was thinking of doing it up anywho and selling it so maybe around january you can look into this. im on the fence about keeping my red or swapping to fp black but so little details about the black now so im going to go ahead and continue on my buying spree. ill save injectors and whether to keep the red or swap to black till december when ill have the motor put together.
#35
I am leaning towards the buschur 2.3. You're gonna wanna keep your block because it will be used as a good core otherwise youll pay another $1000 for core charge.
Im gonna play russian roulette and leave the car as is right now for a good 1000 miles and if it holds up then great, if not ill eat the core charge i guess. I under estimated the power im making, im not so sure i want to skip up to 500whp just yet.
#36
After the mess I went through (and am still cleaning up) I'd definitely recommend the rods and pistons.. I see someone mentioned the stock shorty being safe to 600whp.. this may be true however the torque is going to be the trouble.. if I had to do this over again, knowing what I do now, I'd have kept it less aggressive around the 4000-5000 area... lots of guys going over 500whp on stock block... most with bigger turbos, more lag and no torque peak.. not the same thing as what your car and mine have. I've turned up alot of advice from tuners recommending not to go over 425 to 450 wtq. on the stocker...
#37
The black is basically a bolt on 35R turbo from what i was told by fp staff with less lag and more potential on pump gas.
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
![Thumbs Up](https://www.evolutionm.net/forums/images/smilies/smilie_thumbsup.gif)
p.s i know somebody selling a 2.3 for 3000 NO CORE might be able to talk him down some more if your serious about buying it
#39
EDIT: NM I remember you. But I think whoever tuned your car squeezed it for all it was worth and the tune was probably knock prone?
plus you're making almost 50WTQ more then me, thats quite a difference when we are talking stock internals. Regardless..... I will have a 2.3
in here eventually. I have about 300 miles on the tune so far. Just taking friends for rides alone probably put 20 miles on the car. plus your
numbers were on cobbs low reading mustang dyno, mine are dynojet. thats probably another 20-30WTQ diff.
#40
what are you talking about LOL. look at my sig
. I got a Brand new 2.3 shortblock assembled brand new parts for 2000 shipped no core
. Reason why i can sell my longblock. Thats what looking around fishing and hunting for parts gets you. In fact Everything on the new motor is separte NO CORE EXCHANGED at all on any parts and i paid waaaaaaaay under cost you just have to look around and keep your eyes open for the crazy deals with this economy bad right now lots of people are selling great things dirt cheap right now and my mod list is living proof of that. i have not even paid close to full price on anything on the new block im building
ill send you a parts list if you want.
#41
nope shop builted and tested of course. you know it does not have to be buschur or ams to be good. ill leave it at that. now if you want a buchur 2.3 then nope typac has been trying to sell his 2.3 buschur shortblock no core for some time now. you can look into his if you want that brand
#42
#43
Anyways sorry for the OT, that's some great power on stock ECU and also stock maf?
#44
Yes, E85 on the dyno, and then a retune at the track for E75 or 80, can't remember what it was...
I doubt it... although I did not log it, Tym Switzer has been doing 4G's since the beginning... hell he even made the first coil on plug ignition for DSM back in the day. I've had all my tunes done from him since I just had stock turbo cams and exhaust, never had a problem.. However, more importantly is what happened to the engine.. instead of damage to the piston tops, rings or plugs like you would see with knock, the connecting rod broke in half right in the middle of the beam.. from what I've been told that is from pushing it past the rod's limit for torque.
Mine are dynojet.. but I know the one you're talking about, it's dyno is on the FP site.
I dont get on it until my rpm's are atleast 4k or higher now, anything lower is asking for trouble.
#45
