500whp 100% stock appearing turbo
Old Nov 2, 2009 | 02:40 PM
  #46
scheides's Avatar
EvoM Moderator
Originally Posted by GST Motorsports
Indeed. It held more boost and didn't leak like the crushed BOV was so I was able to add some more ignition timing as well.
I have a uber crushed OEM bov in my personal Evo and it gets annoying on slight grades. When I go to Tahoe over donner pass it's actually makes for a "lively" experience on icy/slick roads when you have to give the car some opposite lock when the surge makes the back end kick out.
Ok so you know what I'm talking about. If this bov indeed can make power over a crushed IX valve AND gets rid of those conditions, I may be buying one. Any chance you can positively confirm that it does away with that annoying issue?
ps--damn you, I had no plans to touch my car for a while. Now the thought of an uprated comp wheel and this bov....gah!
Old Nov 2, 2009 | 02:52 PM
  #47
GST Motorsports's Avatar
Let me try to get him on here and discuss it.
Here are some photos of it:
you can read more about his install here: http://evoempire.org/index.php/topic...post__p__96189
Old Nov 2, 2009 | 02:56 PM
  #48
Originally Posted by jid2
The APS BOV fixed all those issues for me, and it's a direct swap for an OEM part. The Synapse was my next choice. Why no upper IC pipes, just to remain stock looking? Good power for sure - time for another fuel pump.
Yea we have a BR HTA35R 2.3L on E85 making 557whp on our dyno that moved to the APS BOV from a Greddy and it fixed all his boost issues.
The OEM upper IC pipes work great at this level, and do look stock. He has samco couplers however.
Old Nov 2, 2009 | 03:22 PM
  #49
mrfred's Avatar
That thing is huge.
Awesome power. I wonder if the AEM rail is what allowed the car to go to 500+ whp on a single Walbro.
Old Nov 2, 2009 | 03:28 PM
  #50
Mautofied.IS300's Avatar
Awesome, the exact setup I have been trying to plan. 2.3 with BBK-XL (can't wait until the billet is tested) and stock everything. At least stock on the outside with some nice porting on the inside
I would have thought you might have been able to squeak out a couple more psi, but I assume the pump issue is your limit?
How are those BlueMax 1250's? I want to run pretty much the same setup down the road, and want to make sure I have enough headroom. I don't want to get the 1250s and find out down the road I need the 1450s. Or get the 1250s and run almost 100% idc.
Thanks,
-Will
Old Nov 2, 2009 | 03:43 PM
  #51
CBRD's Avatar
we always use APS' if our clients agree to do so!!
this is one of the BETA BBK-B's lol lol (i have to call it that, because it sounds sooo funny lol)..
im always willing to send bryan something to tune and test for his clients....
I value his opinion as much as my own employees when it comes to development!!
we will have more info for you guys shortly...
the final version will be slightly different
cb
Old Nov 2, 2009 | 03:48 PM
  #52
rawkus's Avatar
Looking at the first graph of the Beta vs Regular BBK, it appears the Beta spools faster, am I reading this right?
Dan
Old Nov 2, 2009 | 04:09 PM
  #53
CBRD's Avatar
Dan
the BETA is on a built 2.3
2.0 had the original
it will offset slightly the other way if they are both 2.3's
cb
Old Nov 2, 2009 | 04:21 PM
  #54
94AWDcoupe's Avatar
awesome build. awesome results for stock appearing. do these BM 1250s have any idle/ drivability issues? and was the pressure relief modded on the walbro?
Old Nov 2, 2009 | 05:36 PM
  #55
cb
The 2.0L vs 2.3L overlay I posted where both with the BBK Full (non BETA) in 3rd gear.
Here is another 2.0L vs 2.3L overlay on a different Evo with the BBK Full (non BETA):
https://www.evolutionm.net/forums/ev...l-vs-2-3l.html
Old Nov 2, 2009 | 05:40 PM
  #56
The FIC BlueMax's take a little more time to dial in then other injectors but they seem to be pretty solid now.
Walbro is unmolested.
Old Nov 2, 2009 | 06:04 PM
  #57
scheides's Avatar
EvoM Moderator
+1, good call. Prolly just eeked the last little bit out of it.
Old Nov 2, 2009 | 06:35 PM
  #58
That and the AMS fuel return line are the only differences fuel wise between this and the other evos that run out of pump at less power so most likely.
- Bryan
Old Nov 2, 2009 | 06:37 PM
  #59
sleeper04's Avatar
cant wait to see some numbers with this turbo on a pump gas (91-93) 2.0L !!
Old Nov 2, 2009 | 07:47 PM
  #60
CBRD's Avatar
Doh,
im sorry bryan
cb
Quick Reply: 500whp 100% stock appearing turbo
