E85 + BBK Full + Evo 8
2003 Evo 8
Mods:
STEVO8 Spec ported BBK Full turbo
STEVO8 Spec ported Exhaust mani & Intake mani
Kelford 272's
Blox cam gears -2/-4
Forge WGA
Tomei BOV
AEM intake tube W/Perrin filter & vibrant maf adapter
ETS uicp
AMS licp
Perrin fmic
Milspec 65mm TB
AMS fuel rail
RC1200cc injectors
Titek V1 O2 housing
megan 3" DP
testpipe
3" catback with 16" resonator & muffler delete
Zeitronix Wideband
GM 3port boost solenoid using ECU-controlled boost
Stock motor
Stock MAF
Stock ECU
GST Motorsports custom dyno tune
Tephra V5 map switching (EcuFlash)
91 oct / E85 maps
This Evo 8 made great power for our dyno. Highest stock motor BBK Full on E85 on our dyno to date. Weighs just a little over 3000lbs as well so it's a quick one.
445 whp / 394 wtq on E85 (28.5 psi)
369 whp / 326wtq on 91 oct (25 psi)
+76 whp / 68 wtq gain from 91 to E85!
Here is a overlay of the BBK Full on E85 and a ported stock Evo 9 turbo on E85 (same car):
Mods:
Kelford 272's
Forge WGA
Tomei BOV
ETS uicp
AMS licp
Perrin fmic
Milspec 65mm TB
AMS fuel rail
RC1200cc injectors
Titek V1 O2 housing
megan 3" DP
testpipe
Zeitronix Wideband
Stock motor
Stock MAF
Stock ECU
91 oct / E85 maps
Thanks to both of you guys for awesome service. I think of you guys every time I break loose in third gear as Im pulling away from Z06's..
Sexeh, and awesome peak numbers and killer powerband!
Is timing and/or boost a bit low in the area around boost onset? Kinda weird to see torque go up and then slowly rise like that, definitely safe/nice on the stock bottom-end though
Nice work as always bryan.
I know bryan had mentioned to me on a couple of the cars recently he had been tapering the boost and tune so it didn't spike the torque... so it doesnt break things
Pretty smart
cb
Pretty smart
cb
2003 Evo 8
Mods:
Kelford 272's
Forge WGA
Tomei BOV
ETS uicp
AMS licp
Perrin fmic
Milspec 65mm TB
AMS fuel rail
RC1200cc injectors
Titek V1 O2 housing
megan 3" DP
testpipe
Zeitronix Wideband
Stock motor
Stock MAF
Stock ECU
91 oct / E85 maps
Mods:
Kelford 272's
Forge WGA
Tomei BOV
ETS uicp
AMS licp
Perrin fmic
Milspec 65mm TB
AMS fuel rail
RC1200cc injectors
Titek V1 O2 housing
megan 3" DP
testpipe
Zeitronix Wideband
Stock motor
Stock MAF
Stock ECU
91 oct / E85 maps
Me too and we ran it that way for a while but now I no longer have a daily driver so I gotta make sure the Evo lasts until I can pick something else up. Really I don't notice the lack in tq though down there. The car weighs 2980lbs with a full tank so I moves alright since I only see sub 4k when first getting on the gas. Also if anything it helps with traction in first through thrid which it still has major issues with.
Not at all. I'm on 285 wide advan ADO7's and it still spins all four in first and second roll ons. Plus now it makes 70whp more out at the top end so if it gets spinning in 2nd it continues to spin. The stock turbo tune was a ***** out tune at around 31/32psi to see where we could push the stock turbo to(my car was the highest hp stock turbo VIII on this dyno). This tune is a nice street tune at 28.5psi since it's my daily driver.
