Stock turbo + 272's = 380hp 400tq
nice numbers...your setup is very similar to mine. Just need the fuel pump, injectors and I can go SD and e85 on the same day...I want to get numbers similar to that on stock 8 turbo.
Sorry guys,,, I must have forgotten all about this thread,,, This evom dyno section moves quickly...
I'll try to reprint the graph with the tq curve,, It's a little sketchy since the tach pickup wasn't too good.
The cosworths aren't really working to their full potential yet since the exhaust still needs to be free'd up.. ( High flow cat and still on stock o2 housing ). Stock cams on 27psi already made 404hp on pump. ( see the other SD thread/youtube vid ).
As soon as the exhaust is opened up I promise you will!!
Thank you sir!!
We made 390/390 on a stock 8 turbo with SD and pump gas ( see other thread),, you should be fine!!
Third gear sir!!
How's your beast coming along??
Thanks again!!
Third gear sir!!
Thanks again!!
