BBK Full + SD + 91 + Tephra V7
Old Jan 18, 2010, 11:38 PM
  #46
willitas34's Avatar
Originally Posted by NameLess AZN
a rally cat is a hollow cat(incase a cop here in cali decides to look under your car)
^^^ Curious, have they ever really looked under your car? Not for anyone I know up here in nor cal
Nice job Bryan, never cease to amaze
Old Jan 19, 2010, 10:25 AM
  #47
javicracer's Avatar
how much is for the SD conversion?!?!?!
Old Jan 19, 2010, 10:31 AM
  #48
L888Apex's Avatar
I've had a couple friends with evos say that a cop actually took the effort of laying down and looking under their car
Old Jan 19, 2010, 10:50 AM
  #49
ChuckP's Avatar
They have a mirror on a stick, so they never even need to leave their feet. Yet ive never seen them use it before.
Bryan's recent BBK tunes have me wondering if i really need a BBK-B. I can have stock like spool and reach the limit of the stock block with just a BBK.
Old Jan 19, 2010, 10:57 AM
  #50
boostedwrx's Avatar
I think a BBK would be able to max out the stock block, if not come dang close.
Old Jan 19, 2010, 03:57 PM
  #51
GST Motorsports's Avatar
Parts wise you need:
1. GM AIT sensor (Installed in extra bung on intake manifold or you need to get a bung welded into the UICP)
2. MAP sensor (JDM/Evo 10 3 bar or Omni 4 or 5 bar)
3. Way to delete the MAF (Some intakes you can just stick a filter on the end, others you would need a metal adapter)
Tune wise I've been doing the for the same price as a normal initial tune, however the SD tunes do take a bit more time to get everything working well so I'll be starting to book an extra hour on top of the regular tune.
- Bryan
Old Jan 19, 2010, 04:29 PM
  #52
MJ23FE's Avatar
- Bryan
Thanks for the list, Bryan!
Which bung on the intake manifold have people been using? Also, if someone did decide to weld a bung on their UICP, is there any spot in particular that it needs to be?
I love the results I've seen so far with the swaps over SD, especially in regards to the comments on the increased driveability of the cars afterwards.
Thanks for the great work!
-Jalal
Old Jan 19, 2010, 11:54 PM
  #53
Domolution's Avatar
Bryan @ GST can tune.....this car is amazing.
Thing pulls like a ****!
Old Jan 21, 2010, 06:25 PM
  #54
soontobe's Avatar
Bryan,
Have all your SD tunes had a AIT sensor? Or are you using the fuel tank sensor as well?
RJ
Old Jan 21, 2010, 06:36 PM
  #55
Originally Posted by soontobe
Bryan,
RJ
All SD use GM IAT (MAT) sensor, just two different ways to input it into the ECU. Either through the fuel temperature ADC input or the factory MAF IAT wire.
This particular Evo had the GM IAT sensor mounted in the OEM intake manifold and inputed via the Fuel Temp ADC (ADC_0E).
- Bryan
Old Feb 26, 2010, 01:14 PM
  #56
EvoM Community Team
golgo13's Avatar
Bryan, do you know what spring your customer was running in their WGA? Blue or red?
Old Mar 8, 2010, 01:03 PM
  #57
EvoM Community Team
golgo13's Avatar
Can you delete the MAF on the stock intake arm or will it work with the Perrin intake?
razorlab
66
Dec 14, 2013 03:58 PM
GST Motorsports
May 20, 2012 06:34 PM
GST Motorsports
Dec 22, 2010 12:37 PM
GST Motorsports
Mar 9, 2010 08:13 AM
GST Motorsports
Dec 23, 2009 10:43 AM
Quick Reply: BBK Full + SD + 91 + Tephra V7
