GT3076r On E85 449 whp 367 tq on 24psi
ps: just to back up what i just said, I DO work at a tuning shop. We work on Evos, supras, 240sx , etc. I pretty much know a bit about car tuning. thank you.
^ I have seen 2 cars at the 600hp+ level with stock headstuds running 30+psi and never had any problems and a **** ton of 500-600hp cars running 35+ never having problems. Headstuds are not needed in the stock motor. The rods or rod bolts will let go before the headstuds will. FACT and you can't argue against me, I don't care who or where you work. You just make them look bad! Call emery and ask him what messed his stock motor up, he had stock everything, minus the snail that gave him over 600hp... It was a rod bolt.
To answer your question, yes. 1st off, to have 700hp you won't have a stock motor and no idiot would not upgrade headstuds while the motor is apart. Second off doing a 1x1 headstud job can cause more problems then if you had left the stock headstuds alone. If the headstuds seem to be stronger than the stock rods and rod bolts then why upgrade??? Save the $200 towards your motor build when the rod decides it's going to go threw the block.
Speaking of stock headstuds, have you tensile tested them to see where they stretch/break... I didn't think so.
My roomy and I have a 240 sr20 black top with a disco potato. Want to take 240s too? I didn't say a word about your tuning so don't get all defensive hot shot; that is if you are the tuner but I don't know if you are or not...
Mikey
and crank boost up to 35psi on a 35r turbo and make around 600-700 whp, is stock head studs still ok????
Mikey
Stock headstuds are a lot stronger then people think.
Mikey
Mikey this guy makes me laugh can't beleave my eyes..lol..Any way back to what he said timing on 10 degrees won't make anypower even on 35 psi =kaboom..please back on topic i hope they post this graph curious to see the power band on this puppy funny i all most bought a 30 r kit before the red..
CBRD
25
May 1, 2008 05:12 AM
