04' evo8 with fpred 80mm and E85 made 462whp, 452wtrg
just wanna share this evo 8 to every body, just tuned it last month , all the mods are in my sigs, thanks. Dyno sheet are attached. Check out the FAT powerband. Over 400lbft at 4500rpm. very nice
That graph is just a peak number u should save your money and let motionlabs tune again very weak looking graph ...also whats your peak timing,load numbers peak on a street tune,and what does your car hold boost at redline???
up 20 degree, back down to 15 peak 30psi taper to 25. done street tuned before too, but there is a shaft seal leak and preload on wg was off. The 387whp is on the street tuned. 462whp is the final tune with couple turn preload and new shaftseal. Full 30psi boost at 3800rpm. Boost/fuel cut set at 32psi. We ran out of time for further tuning.
look at the graph closely buddy, still over 400 whp at 7500 rpm , over 400lbs torgue at 4500rpm, this power band graph look fatter than shaquel Oneal man. )
well u do have a red running on E85 , put up or pm me your graph, i wanna see how strong your graph look my friend.
This is on meth and 93 oct.....also look at the smoothing factor it's on 0..The pulls were done on a 3rd gear pull and my car has a 6spd so we should done it in 4th so the turbo would have spooled even faster and would have made more tq and peak power..
who told u 4th gear spool faster than 3rd gear ? U reach peak boost better with 4th gear my friend. Are u on something right now? here your
so u on meth 93, iam on E85. How are we gonna compare graph? I am not sure if meth and e85 should made the same power. I know e85 and c16 are pretty close.
I never touched my wastgate spring and i boost 30.5 psi and hold 30 psi till redline..What wastgate are u running???im gonna post up a better graph pic of mine to view some peak power holding mean compared to yours...Plus peak numbers don't win races holding the power up top and tq does, just view mine compared to some other crapy tune i had..reminder i had three boost leaks..
