Mellon Tuning EVO 9 2.3L 35R 93 oct 541awhp vs old 2.0 setup
Old Mar 31, 2010, 07:00 AM
Mellon Racing's Avatar
Dave when are we going to do a race gas tune on the new setup?
Old Mar 31, 2010, 08:55 AM
L888Apex's Avatar
O_O I want that much tq
Old Mar 31, 2010, 09:21 AM
turbodav's Avatar
Not sure yet but soon
Old Mar 31, 2010, 09:57 AM
RockmanX's Avatar
nice numbers hommie for sure good tuning as usual mellon. Yo when are we going to see the silver evo again mellon not this year??
Old Mar 31, 2010, 09:59 AM
I'll bring it back out his year I'm sure, I wonder what 10:1 and e85 will do
Old Mar 31, 2010, 11:20 AM
RockmanX's Avatar
nice to hear maybe ill beat you and have mine together lol
Old Mar 31, 2010, 11:25 AM
haha probably, I'm not in a big hurry.
Old Jan 17, 2011, 02:54 PM
evo4nr's Avatar
Sorry to drag this one up but i run a similar set-up with RC 1000cc , double pumper and fpr set to 3.5bar . What hp do you think i would run out of injector on 93 pump alone?
Old Jan 17, 2011, 03:04 PM
TakaseEVOIXSE's Avatar
nice job guys!!!
Old Jan 18, 2011, 10:36 AM
~ 600awhp
Old Jan 21, 2011, 02:28 PM
FQ4OO's Avatar
Looks like the GSC cams did the trick.. nice.
is this car still running stock throttle body?
Im curious as i have a fairly similar setup.
Regarding the virtual dyno, what numbers are these comparative too ie: Dynojet, Mustang?
Those Vmax speeds of 230mph+ are impressive, what driveline upgrades does the car have to achieve those speeds?
Old Jan 23, 2011, 02:12 AM
evo4nr's Avatar
mellon whats the highest hp you have seen on 93 on a gt35R 0.82?
Old Jan 23, 2011, 05:33 AM
yes, stock tb and intake mani
dynojet, but this is when I was using DLL which read a little low. Now I use Virtual Dyno which is exactly like a dynojet.
I didn't write down any driveline upgrades he had. Most likely clutch, tranny and tranfere case were upgraded but the rest was stock.
that would be my own car at 600awhp on 93 when it was on the .63 at 9:1 compression and again on the .82 at 10:1
Old Jan 23, 2011, 11:17 AM
evo4nr's Avatar
So you use vdr with the dynojet setting? Might do a couple of logs and see what i get.
Old Jan 23, 2011, 01:39 PM
240Z TwinTurbo's Avatar
From my previous post.....
Originally Posted by 240Z TwinTurbo
While Mellon did well using the .63 a/r, that does not mean the larger a/r wouldn't have benefited him as well. You should see top end gains going to a larger A/R. A reduction in the flow restriction within your exhaust will provide benefit regardless of boost. However, the gains may be more significant at higher hp levels/higher boost. The expected gains will really be dependent on whether the a/r is the limiting factor at this point.
Your response to me....
Originally Posted by Mellon Tuning
going from a HTA3582 .63 to a HTA3586 .82 gave me no more power on 93 octane at 30psi and only added lag. I always speak from experience, not my ***
My point is now proven as he runs 29psi and clearly benefited from the larger a/r.
Quick Reply: Mellon Tuning EVO 9 2.3L 35R 93 oct 541awhp vs old 2.0 setup
