built 2.4 ETS 6235 john bradley tune
#80
the head look to be stock besides the S2'S and valve springs.right now i have the ACT 6 puck clutchwhich doesnt allow me to shift fast and i think if i launch the car it will just slip so i am only going to try for MPH.. i might try one launch to see if i can toast the clutch so it makes me rebuild the quartermaster i just bought and get that in
#82
ok so i did a ported stock intake manifold and we put it back on the dyno last night for a stock manifold that was ported by me (this was my first attempt at porting) i am happy with the gains it got i picked up 20 peak hp... i think it was worth 60 bucks
[IMG][/IMG]
[IMG][/IMG]
#83
Looks good! Do you think the stock port is hurting you up top? I have a 2.4 bottom end going in mine, stock port head with only a valve job, I'm running bigger cams than you but afraid the stock port is gonna hurt my top end.
Either way great gains for a ported intake!
#84
my head is ported i discovered that when i did the ported intake manifold i think my car would gain more out the top if i was to install a magnus...not sure how much it would gain...my next change will probably be cams not sure which ones yet but that will be next
#87
Brandon no longer owns the car, it is now owned by another PNWer that signs on as AnthonyRB. He decided to pick up where Brandon left off and added a Magnus. The car now has a 3" exhaust where it used to have an ETS 3.5 so its a little corked and still has S2s. Nevertheless I am very pleased with the results. 580s were on gas and the 693 was on E85.
I think some S3s and a testpipe dump will make the difference and get this FS635 over 700whp which is the goal.
Aaron
Aaron
#88
Aaron
Aaron
TTP Engineering
Mar 19, 2010 05:15 AM
Paul Nelson
151
Apr 2, 2008 07:25 PM
