Mikey's FP Black *** WOW ***
Old Jun 30, 2010 | 11:27 AM
  #61
Svendiesel's Avatar
Hooooly shnikes. Insane power dude.
One question, these were the custom S2's or are these regular S2's? I remember you said something about the customs not being ready on time or somethin so Im curious if they came thru yet or not.
Old Jun 30, 2010 | 11:41 AM
  #62
Paul Walkin's Avatar
These are 274 duration (s2's) with approximately 12mm lift...
Old Jun 30, 2010 | 11:47 AM
  #63
TJPhillips36's Avatar
Nice, definitely showing what that black can do here!
Old Jun 30, 2010 | 12:19 PM
  #64
RSMike's Avatar
Originally Posted by BLKCarbonEVO
The other thing, at 36psi I'm only holding 27psi out the top. That is another problem that we are going to be fixing over the next week. The flapper will be coming out of my new housing and 38mm MVS will be going on.
I think with the housing, that will fix the backpressure problems we are seeing and the external wastegate will help keep the boost from falling off so much up top.
If you remove the internal wastegate flapper and run an external, expect a 400-600 rpm increase for spool.
I did this exact same thing in my car, and 17psi boost (with 2.0 and FP Red, 2nd gear) was 5000rpm. With the flapper back on, 17psi boost was being made at 4400. A massive improvement. And off boost driving was alot better.
If you want to test it for yourself, just hold the flapper up during a run. I used Lockwire.
Instead of doing that, can you just run a closed loop boost controller?
Old Jun 30, 2010 | 12:23 PM
  #65
MOREPSiTEHBETT4's Avatar
great showing of what the black can do, spool wise and ouput and it still has more to go. This will be an excellent drag car if you decide to take it to the 1320ft proving ground
Old Jun 30, 2010 | 01:15 PM
  #66
F0RSAKEN's Avatar
Congrats man! Sick numbers for sure!
Old Jun 30, 2010 | 01:54 PM
  #67
BLKCarbonEVO's Avatar
You mean with the external I will lose spool. aka turbo spooling later?
Mikey
Old Jun 30, 2010 | 02:00 PM
  #68
Fast_Freddie's Avatar
Veteran: Navy
Great results Mikey, congrats to you, R/TErnie and the English Racing crew for all their hard work on this project!
Old Jun 30, 2010 | 02:24 PM
  #69
lillev23's Avatar
Will you still have A/C with this external wastegate setup, or will it have to be removed?
Old Jun 30, 2010 | 02:29 PM
  #70
Svendiesel's Avatar
Mikey
Seems like he means you will loose spool. Personally, Id rather loose it down low a tiny bit and then have it hold better to redline. Do you really think loosing 300rpm in spool is gonna affect you much when youre already making close to 600wtq?
Old Jun 30, 2010 | 02:35 PM
  #71
lillev23's Avatar
not saying that I don't like the idea of an external wastegate, but would this kinda defeat the purpose of having a stock frame turbo? Would it just be better to have a T3 HTA82?
  #72
nikkadanny's Avatar
nice power. glad i went with some gsc s2's
Old Jun 30, 2010 | 02:41 PM
  #73
lillev23's Avatar
Nice numbers! The Block is a strong one if it is still together at 527tq
Mikey
Yep. It's still holding together pretty strong. I took it to one of the best shops around to get it tuned. Of course I've turned the boost down, I don't race it anymore, and I don't street drive it as much. It's only had 7 runs at high boost.
Old Jun 30, 2010 | 02:57 PM
  #74
RockmanX's Avatar
hmm i would have to agree there whole point is to keep it stock framed. nice numbers mikey for sure.
  #75
38six's Avatar
Congrats, thanks for the info on the gsc cams.
Quick Reply: Mikey's FP Black *** WOW ***
