HKS 272/280 vs. GSC Custom Cams
I know some of you have seen this in my thread but I'll post it by itself too.
This is our cam test going from a HKS 272/280 combo to a Custom GSC cam. Nothing was changed between these pulls but the cams. Everything you see is straight cam power!
Attachment 338718
Mikey
Attachment 338718
Mikey
The below graph is a comparison of the same boost levels for the GSC cams vs. the HKS, both holding 25psi at 7300 rpm. Just to show you the boost for boost at 7300 rpms. The GSCs picked up 52HP, however this particular HKS pull was spiking 31psi in order to match the 25psi of the GSC cams at 7300.
So in a nut shell, the HKS cams had to spike 6psi more than the GSCs to be able to hold 25psi at 7300. The awesome thing is that the GSCs still managed to make 52HP more than the HKS and have a better powerband out the top due to the increased airflow.
Mikey
I think the real question is, why did the HKS cams drop boost up top and not the GSCs? The reason for that is, that the HKS cams were chocking the motor and hindering airflow in the higher rpms. Power is Airflow and the GSC cams just allow the motor to breath. That is all there is to it... The above graph was a direct swap, nothing changed but AFRs. Timing was the same.
*IMPORTANT TO NOTE*
To save some trouble for Greg, anyone interested in these cams can save the phone call to GSC for the time being. They dont have a name so they dont exist.
They are not going to be widely available, they will only be available through EnglishRacing, and they are not drop in friendly. There are definite requirements to make these cams work properly, headflow, springs, turbo size, compression, etc.
thanks
Aaron
thanks
Aaron
*IMPORTANT TO NOTE*
thanks
Aaron
thanks
Aaron
*IMPORTANT TO NOTE*
thanks
Aaron
thanks
Aaron
