CBRD's BBK-B.. 457whp/365wtq on 93..
Old Jul 2, 2010 | 08:16 AM
CBRD's Avatar
This is another test car..
Highest Stock housing, Stock Block 93 car ever on our dyno...
running at just under 30psi.... we apparently are out of fuel pump (walbro 255)... as with 1000's with lean spool disabled we are targeting extremely rich AFR's up top to still creep up to 11.8 ish...
Anyway, here are the mods, this car gained 92 whp over the tomei turbo at 27.5 lbs, the only change was the turbo and injectors.
CBRD fmic, CBRD LICP, CBRD Radiator, CBRD BBK-B, CBRD Tune
JMFAB manifold, invidia o2 housing, tback (2.75" downpipe)
1000cc PTE, walbro pump
Perrin intake, 3 port perrin solenoid, stock coils and plugs
stock intake manifold and tbody
these are third gear pulls, showing 20psi around 3750 rpm...
Ill do a fourth gear pull when I retune it at 27psi... I am not going to leave the stock block at 30psi for the street, but we were asked to run it at that boost level
cheers
cb
Old Jul 2, 2010 | 08:42 AM
Craig King's Avatar
Wow - very impressive CBRD!
Old Jul 2, 2010 | 09:51 AM
CBRD's Avatar
overlayed with tomei, only change was having to upgrade the injectors and the BBKB
please note using the same start and stop speed, the pull took 1.5 seconds less with the new turbo
ill have the owner post his thoughts.
cb
Old Jul 2, 2010 | 10:00 AM
MJ23FE's Avatar
cb
I can't wait to hear his remarks, especially in regards to response.
-Jalal
Old Jul 2, 2010 | 10:07 AM
CBRD's Avatar
he is happy just paid his labor bill
his tomei blew up, which sucks, because he didnt get any money back out of it.
cb
Old Jul 2, 2010 | 10:21 AM
Aby@MIL.SPEC's Avatar
Looks very strong!
8end24, pull #2, conducted on 2010/03/24-25, had a similar cylinder head, cams& fuel used, difference being ams vs cbrd fmic & a few minor parts @ similar boost.....bbk full vs. bbkb
is it possible to put up that compare?
Old Jul 2, 2010 | 10:47 AM
Blazing VIII's Avatar
Wow, the gains over the Tomei are awesome. Guess they put too much R&D into making a cool compressor housing. What is the flow rate on the BBK-B?
Nevermind, found the flow in the other thread.
Old Jul 2, 2010 | 11:18 AM
metalsaber's Avatar
Nice job Chad.
Old Jul 2, 2010 | 11:46 AM
grillpt's Avatar
Those look like some hefty gains with only minimal loss in spool... The B looks very promising... I'd like to see this bad boy running ethanol.
Keep up the good work gents.
Old Jul 2, 2010 | 12:21 PM
red03evo's Avatar
nice #'s
Old Jul 2, 2010 | 01:09 PM
CBRD's Avatar
Originally Posted by Aby@MIL.SPEC
Looks very strong!
ill get it overlayed on monday for you, i should be able to pull it up,
ill check if its the same gear and make some notes too!
cb
Old Jul 2, 2010 | 01:26 PM
K1tt3n5's Avatar
Looks great Chad!
Old Jul 2, 2010 | 01:28 PM
JDMevoBOOST's Avatar
Sweet Jesus almighty! This looks to be a good turbo to play with when the gf is sleeping in the passenger seat...BWAAHHHHHH lift....BWAAAAAAAAAAAAHHH lift!
Old Jul 2, 2010 | 01:33 PM
evoforlife's Avatar
nicely done, what would this power be on a dynojet?
Old Jul 2, 2010 | 01:34 PM
kreionic's Avatar
Like i was telling you yesterday chad. Im very very impressed with this turbo. The curve on it is awesome and was very consistent from car to car with the graphs you showed me and with what i saw myself. Making me think hard about going back to a small set up
Quick Reply: CBRD's BBK-B.. 457whp/365wtq on 93..
