FP Black, 27 PSI, 93 oct, Stock Block
if you get the log of that run give it a try in this virtual dyno too.
http://www.mellontuning.com/index.ph...4c024c1a0bc851
is your car lightened up because the weight should be higher unless 03's were lighter. i found most use 3260 for weight or there about for non rs models. this will bump your figures up.
I had the black and was never a fan of these stock framed turbos..But I see people are happy with them and there running some pretty decent times with them and they make some nice street power..
The only thing I don't like about them is they fall of of power and that there journal bearing wheels and when pushed at high boost levels they tend to fail quit easy..
If you get your 60 ft to a 1.6 you should run 11.2 ALL DAY.I can't believe you sold your old hts 35 r setup for the black I wish you would have tried the t3 setup first maybe now your eyebrows would have been peeled of by now.
Not bad .not bad at all brother..I'm gonna lower my launch map cause I'm coming out a little to hard I'm lanching at 16psi at 6,400 and it feels nuts ..what's your 2 step and boost set at for launching?
