FP Black, 27 PSI, 93 oct, Stock Block
Old Aug 17, 2010 | 11:21 AM
5LEEPERISAH23I's Avatar
After turning up the boost, the car made good numbers, I am extremely happy with the results!
It was super hot out also when it was getting tuned.
Mods r in signature below if curious.
I took it to the track and ran an 11.91 @ 119.79 with a 2.01 60ft.. Yea if only i could launch right.
Old Aug 17, 2010 | 11:34 AM
scheides's Avatar
EvoM Moderator
command-shift-4 and you can do screenshots with ease on a mac
FP Black is for big boost. Get some Alky or E85 in that thing and crank it up! I made 430 with my baby BBK.
Old Aug 17, 2010 | 11:52 AM
awddyno's Avatar
Nice. I have to try a pump gas tune soon. I doubt I will push it past 350whp. I
Old Aug 17, 2010 | 12:06 PM
ha thank you did not know that, will do next time!
yea the only reason i got the black over red n green is bec im planning on building the motor soon. but for now on a stock motor 434whp im very happy with
Old Aug 17, 2010 | 04:35 PM
EvoLeoIX's Avatar
Build it with a 2.3 then add the Fritos to the gas tank. Nice powa
Old Aug 17, 2010 | 05:15 PM
zeus1's Avatar
that is some good power for those temps.
Old Aug 17, 2010 | 06:38 PM
MR Turco's Avatar
graph looks odd. What are you using for boost control?
Old Aug 17, 2010 | 06:55 PM
tscompusa2's Avatar
turn weather correction factor off and change smoothing alittle.. better yet post the raw log here and ill paste your results better for you. the more you smooth the more it hides the real torque.. your to much smoothing could be showing less power.
Old Aug 17, 2010 | 07:04 PM
im using a MBC? not sure if that answered ur question
Old Aug 17, 2010 | 07:06 PM
Wink
going with a built 2.0 when time comes
yea thanks he put alot of time into it
Old Aug 17, 2010 | 07:10 PM
metalsaber's Avatar
Yeah, definitely turn off the weather correction and lower the smoothing.
Old Aug 17, 2010 | 07:13 PM
zeus1's Avatar
once the temps cool down that power should jump considerably.it would be intersting to see a run graphed in the winter on your car.
mchristian's Avatar
I have almost the exact same mods...installing FP Black this week and was expecting closer to 450-475 whp....on 93 pump and at lower boost?
I'd certainly be happy with 11.91 @ 119.79 with a 2.01 60ft!
Old Aug 17, 2010 | 07:15 PM
i dont have the raw log any more i think i deleted the email of that ill check tho, when i made
the smoothing factor at 1-2 it had more tq and hp like 446whp n 368wtq
Quick Reply: FP Black, 27 PSI, 93 oct, Stock Block
