Dyno results @ AWD Motorsports Video and Chart Inside!!!
Trust me I know what its like for your car to be down, and to the money part, thats exactly why I would have waited so you dont pay for a tune and labor twice. As far as the cams go, but you getting other parts that will take longer to get. What ported tb/Im you gonna get?
Thanks guys
Yeah I'm going to be doing a few things to clean it up though and make it hit sooner, i didnt think I was going to wind up building the bottom end so I had the Green before the decision to build came into play, if anything I am going to ship it out and go black and totally skip the red.
The peak numbers are good for stock cams. I have seen spool losses and improvements with cam changes. On most setups stock cams spool the fastest. The green at 27psi and up should net about 300tq at 37-3800. This setup is hitting late for sure. Installing a black will make problem much worse. My guess is the tubular exhaust manifold is most of the the problem. Hard to tell on paper where the other restrictions are.
turbos dont make horsepower. good setups do. always best to have your setup flying on a small turbo before adding the big turbo. large turbos struggle more than small turbos in restrictive setups.
So you think that the tubular manifold is hurting me bad right now?
Electricevoix is a good friend of mine and we have basically the same set up and posted his dyno results with Akuma Motorsports w graphs. He has Cosworth M3's and a tubular manifold and was tuned on pump.
I have the tubular manifold, NO cams, but running E85
His dyno results showed that power came on much sooner than mine so it would lead me to believe that the cams is the issue?
Also Mike said I was getting soft preload which could be an issue was well.
there was a couple of posts years ago from two guys who replaced their tubular manifold and went back to factory. both dyno graphs showed they gained 60tq around 4000rpm. both were rave reviews. Then there is the constant barrage of shops claiming 15 to 20hp gains with minimal spool looses. hard to tell who is telling the truth. I have personnal tried tubulars and think they have no business on street cars if there is a cast manifold available. tubulars expell a ton of heat into engine bay. I remember years ago I met a guy who had a temp probe in engine compartmant. He measured 175 temps with cast manifold. and 325 with a tubular. during summer months in NJ. Image the turbo has to ingest 10 cubic feet of air every second at 400whp. that means sucking the engine compartment dry twice every second. makes CAI very important.
soft preload will definitely spool slower. that means you are loosing twin scroll effect early during spool.
I have installed hks280 cams on a 35r setup. we were concerned about spool differences. the 280 cams spooled the turbo 750 rpm slower over stock cams. but as stated before i have seen the opposite happen as well. its possible to pick up a couple hundred rpm from the right cams.
e85 spools a few hundred rpm faster than gas on this size turbo.
Nice power, but why would you build the motor and not put cams into set-up like this?? As a shop I think Mike should have said whoa???? I dont understand unless you are going to try and test some cams??
This combination was done with somewhat of a budget in mind to get the car on the road.. I suggested the Stock manifold, he knows he needs cams, Ported IM and TB will help.. So understand when you expect to spend 1000.00 on something and then you end up finding out you NEED other parts that double that amount it doesnt always leave extra $$$ for the parts you dont NEED but parts you want.. So we will add to this combination over time.. It makes it more fun as well to know what you bought and how much you gained a few parts at a time not throwing the kitchen sink at it..
That Manifold is KILLING the spool worse that the actuator.. Im sure of it.. But with both the right parts on we will be bale to show a good before and after i am sure.. so stay posted..
Mike
Mike
