Dyno results @ AWD Motorsports Video and Chart Inside!!!
#33
The peak numbers are good for stock cams. I have seen spool losses and improvements with cam changes. On most setups stock cams spool the fastest. The green at 27psi and up should net about 300tq at 37-3800. This setup is hitting late for sure. Installing a black will make problem much worse. My guess is the tubular exhaust manifold is most of the the problem. Hard to tell on paper where the other restrictions are.
turbos dont make horsepower. good setups do. always best to have your setup flying on a small turbo before adding the big turbo. large turbos struggle more than small turbos in restrictive setups.
Just use the stock exhaust mani
#35
Invidia manifold looks nice but trust me it is a complete piece of junk IMO, spool up was horrible and my power band was ridiculously short, I wouldnt buy one if I were you.
#37
*** If you look through posts that I have commented in you can link to the updated dyno session and see the difference it made when I added the stock ported/coated Buschur manifold and a 25 psi Forge WGA, the car feels a million times better!!!***
