FP BLACK installed
FP BLACK installed
Well guys I just installed an fp black that i purchased from Gary@mellon tuning with low miles and am getting a tune from AMS on the 28th. I'll post up a dyno sheet when its finished. In the mean time what do you guys think she'll pull on the mustang?
This will be tuned on low boost with e85 fuel. Dont want to go back to 93.
stock block
FP black
EPM o2 dump
880cc injectors
walbro 255
HKS 264 cams
AMS fmic lower and upper pipes/ tbe
ARP headstuds
exedy 12 lb flywheel
SAMCO bov
? Thinking of upgrading rod bolts to turn up the boost but i'll still need bigger injectors to do that...what do you guys think?
stock block
FP black
EPM o2 dump
880cc injectors
walbro 255
HKS 264 cams
ARP headstuds
SAMCO bov
I wouldnt go much above 400 whp on e85 with those small injectors. Also wat do you consider low boost? At 30psi the Black is capable of 500+whp depending on mods so I would say you are limited by how far you want to push the injectors and single walbro. Is it a modded walbro or a stock one? That will make a difference as well.
