540hp FP Black Stock Motor
This is the highest HP stock block engine I have ever tuned on this specific dyno. Evoscan logged 64 lb./min. through the stock airflow meter. Any more airflow will require some WG adjustments if at all possible. The goal here was to keep Tq. as low as possible and gain as much top end as possible for drag racing. With this and the stock motor in mind we did not want to sustain the extreme boost pressure at low rpm usually needed for this kind of boost up top with a MBC. This is also the highest hp stock frame turbo I have done and the injectors are past their limit. Pulls were done in 3rd gear. Peak boost was 33.4PSI
E85, about 77% Ethanol
No correction, corrected numbers were about 7 less hp. If it was corrected the graph would show "engine power T WC"..
Just usual suspects. FP4r cams, JMF 02 dump, tubular manifold, injectors,doublepumper, gm 3 port, stock intake manny. Nothing crazy, just a good combination..
