English Racing SD Evo 9 HKS7460 E85 - Results are in.
Old Oct 18, 2010, 04:14 PM
R/TErnie's Avatar
I recently picked up an HKS7460 Turbocharger from Sean Ivey (Iveytune) and did some testing! Huge thanks to Aaron and everyone at English Racing. Aaron's SD magic and tuning ability is uncanny. I'd like to say that I tuned this car myself, but Aaron tuned this car SOLID without even making a dyno pull. I told him the specs on the turbo and my mods and he produced from thin air a map that... without exception was SPOT on at every boost level. Aaron really can tune a car is less than 3 pulls, because he did mine without making a pull.
Big thanks to all the people who helped me to make this happen!
Aaron @ ER
English Racing
Sean and Sam @ Iveytune
Extreme Turbo Systems
Magnus Motorsports
2020 Motorsports
Fuel Injector Clinic
Mr. Fred (Mychailo)
Matt Nucci
Boostedwrx (Jeremy)
Bill@Drift Office
Evolutionm.net
Mod List
2006 Evo 9
48k mile Stock Block (head studs and rod bolts too!)
Unported Head
HKS7460 Turbocharger (ported by myself)
FP Oil feed line and filter
RNR 3" Turboback
FP4R MIVEC Cams
Kiggly Beehives, Ti retainers, and spring seats
AEM Tru-Time cam gear
Magnus v5 (ported and modded by myself)
TiAL 50mm BOV
Nisei LICP
Nisei Mini Battery Tray w/ Odyssey Mini Battery
STM -6AN valve cover fittings
Earls pro-lite hose and fittings
Peterson Catch can
Full Blown Housing w/ twin 255 Walbro's
Nucci-SPEC twin pump wiring, AN plumbing, and install
FIC 1680 High Impedance Injectors
Spoolinup COP setup
Denso IKH24's gapped at .018"
English Racing Speed Density Conversion (using fuel temp ADC)
Tephra v7 Modified by Mr.Fred
OMNI 4 Bar map sensor
AEM 3 port EBC w/ R/TErnie .040" inline restrictor
AEM wideband
E85 Fuel
Parts that I fabricated myself
Parts not for sale. Please do not PM or ask.
3" SD Aluminum Intake with K&N Filter
FMIC (22x12x3.5 Extreme Turbo Systems (ETS) core)
UICP
3" v-band o2 housing
Modded DC sports 3" Downpipe
Dyno
Dynojet 424x-LC dyno @ Drift Office in Auburn Washington. A DJ makes about 13-15% more power than a Mustang dyno. My equivalent MD numbers would be 428whp.
Evo IX (92)
- 3" DP and TBE
- HKS intake
HKS7460 (E85)
Evo IX (110Leaded)
- 3" DP and TBE
- HKS intake
- Magnus v5
- COP setup
- SD
- UICP w/TiAL
versus HKS7460 (E85)
FP Red (c16)
- Same setup as HKS MINUS FP4R cams, SD, and E85
*****NOTE: FP Red Pull done in 4th gear versus HKS done in 3rd gear*****
3rd gear Dyno pull started at 2k with a coast down (minimum turbo speed before WOT)
My FP Green setup on E85 (don't mind the wavy dyno pull...) FOR COMPARISON PURPOSES ONLY
HKS 7460 Boost Plot for 4th Gear.
pull starting at 2500 in 4th steady state.
10psi 2750RPM
21psi 3000RPM
30psi 3250RPM
37psi 3750RPM
37.5psi 4000RPM
36.5psi 4500RPM
35psi 5000RPM
33.7psi 5500RPM
31.6psi 6000RPM
29.5psi 6500RPM
27.3psi 7000RPM
25.2psi 7500RPM
24psi 8000RPM
couple pics of the setup.
My comments
The torque is instantaneous. Its hard to describe, but the boost sequence is missing the lag and spool section.
before(FP Green on E85):
WOT->LAG->SPOOL->POWER
now (HKS7460)
WOT->S-POWER!
From my comparisons at the dyno this turbo is identical powerwise to the BBK, except that the HKS turbo out spools the BBK and has FAR better transient response. I should have that overlay for people tomorrow afternoon. Jeremy compared our very similar modified Evo 9's on ER SD/E85... you couldn't discern the two after 4000RPMS.
I hope to come back to the dyno with a ported exhaust manifold and a MIL.SPEC 65mm throttle body to crack 500whp
Thanks for reading. -Eric
Old Oct 18, 2010, 04:22 PM
dbsears's Avatar
Are you referring to Boostedwrx car on the BBK? Didn't his car break 500whp without a Magnus and a little less boost though? Regardless that looks like a stroker powerband damn near. Gonna be nuts on the road course!
Old Oct 18, 2010, 04:23 PM
TK40's Avatar
You are the man Ernie. I hope you hit your 500whp goal soon!
Old Oct 18, 2010, 04:24 PM
R/TErnie's Avatar
Correct... its strikingly similar to this power curve. Granted there are some differences in the setups, but...I'll say again... VERY similar except for the spool up
Old Oct 18, 2010, 04:31 PM
JohnBradley's Avatar
Derek,
Some of this could be cams, some turbo, some weather conditions.
Eric, thank you for the review. As a friend and colleague its nice to get a pat on the back like that I will be trading you tech I am sure when I embark on phase 2 of my rally testing and rely you on as our R&D engineer on the drag car.
aaron
dbsears's Avatar
Too bad you are in B-ham I would love to go for a ride. I think the BB center has me going to pull the trigger on this over the BBK though...I'll have to see. That spool and I assume transient response is killer. A 4cyl that feels like a V8 all while producing almost 500whp = money!
Old Oct 18, 2010, 04:48 PM
dbsears's Avatar
Well hot damn! Yea Bremerton is my stomping grounds, I will make it a point to be there!
Old Oct 18, 2010, 04:50 PM
R/TErnie's Avatar
Lucas has made over 500whp with a stock 9 turbocharger. Why get a HKS turbo?
#1) Given the design of the BB CHRA it can take excessive thrust loads that a journal bearing cannot endure. Durability.
#2) the BB turbocharger kills the Evo 8, Evo 9, FP white, FP Green, BBK, you name it... KILLS in spool time. And we haven't even touched the best part.
#3) Transient response is out of this world. The time for this turbo to come to life with no turbospeed transitioning into a WOT condition is minimal at best. It REALLY makes the stock turbo and the green look bad.
#4) This was on a stock Evo 9 engine, not a built engine (if you would like to elaborate on the setup you're comparing... compression ratio, displacement, headwork, etc)
Ivey has shown what this turbo is capable of on a stock setup. You get better than stock spool and you're capable of hitting 490whp...even 480 with minimal mods and 100octane
I think its pretty obvious why the HKS turbo rocks Dave.
Old Oct 18, 2010, 04:55 PM
David Buschur's Avatar
It would be interesting to compare to the stock turbo on Dan's beater. Curt's HTA Green too considering it ran 10.7 at 137.xx on pump gas at 30 psi this weekend. Hard to beat the HTA Green based on those results.
Old Oct 18, 2010, 06:39 PM
dbsears's Avatar
Yes it does outspool the stock IX and like said transient response is FAR better. I suppose when your banging gears at 8k for 10sec it doesn't matter. For some people having quick spool and response is a priority (ie road course...place where you actually turn and must downshift
The HTA Green most likely flows a touch more and will make all out power on kill but this turbo is directed a bit differently...Comments based on saying it hasn't ran 10's yet well it already pulled a 11.0 out in Iveys thread in a full weight car with minimal mods and this is the only the 2nd-3rd one even dynoed in the US since they came out. So Mike and David you of all people should know to give it some time to prove itself. HKS has proved itself in other venues so it will have it's place.
Its pretty obvious it flows more than a Stock VIII or IX turbo so making claims against somebody else's car is a moot point. Guarantee if somebody made "410" on a stock VIII then one would make more with the HKS given the same car. Just my 2 cents.
Old Oct 18, 2010, 07:01 PM
Brandon03Evo's Avatar
the graph were it out spools the 9 turbo looks like they started the pull about a 1000 rpms later ....
Old Oct 18, 2010, 07:07 PM
R/TErnie's Avatar
Brandon the first graph is the Evo IX turbo too... started almost identical times...
Don't forget you guys. The IX turbo on 92 octane was done with stock cams and stock Intake manifold. The HKS turbo was done with FP4R's and a Magnus v5 intake manifold...with a 22x12x3.5" FMIC.
So not only does the HKS turbo outspool the Stock 9 turbo... but it did it with FP4R's and a Magnus v5 as well.
Reason why the 110 octane green pull was started later was to keep the torque down. The wastegate had lots of preload and NO boost control. Thus the 110 octane... worked great at PGP. 1:10:0x's
Old Oct 18, 2010, 07:14 PM
tscompusa2's Avatar
id like to see this thing on a 2.3 or 2.4. i can spool the black up 33psi by 3850 so what would this thing do? 3000? thats crazy. its like a 16g on steroids. nice engine bay and good tune.. looks like you could run more timing uptop though with e85. i run 2 more degrees then that.
Old Oct 18, 2010, 07:19 PM
R/TErnie's Avatar
I did timing sweeps on the dyno. There was nothing left on the table. I was about 2hp per degree of timing... so very close to MBT.
I know this because I pulled 2 degrees of timing across the whole map and look to see a constant offset in torque. I also look at how much power the car loses and where. If for example I had lost 10hp by retarding the ignition timing by 2 degrees at 7k... I might agree with you. But in this case I lost 3hp. 485whp when I pulled 2 degrees across the board.
So... with all certainty... NO this car cannot use more timing up top.
By reducing power output of an engine by 1% off MBT you cut peak cylinder pressure in half.
Old Oct 18, 2010, 07:22 PM
did not see that....woops.... turbo looks like fun.... not trying to question the results just curious about them...
Quick Reply: English Racing SD Evo 9 HKS7460 E85 - Results are in.
