Mustang vs. Dynojet and some amazing numbers
Great information and thanks for posting it up. That is a big spread in power. Switzer performance is right down the street from here, he has/had an AWD Dynojet. His dyno to mine and Mike at AWD's dyno to mine is about 13% difference, mine being lower. BTW, Switzer only uses our dyno now, his is taken apart and under a cover, I guess that says what he prefers He did some datalogging on his dyno, then the road on the way here and then on our dyno, he saw what the facts were. Road compared to our dyno were spot on the money, boost, spool up, AFR's etc. Anyone want to buy an AWD Dynojet? Contact him.
I was wondering what that was all about as well. But from what I understand a dynojet just takes roller speed and time to determine hp so I was under the assumption it didnt matter what engine rpm was. How can a dynojet spike upwards if there isnt a roller acceleration for the instance? I am sure you are more familliar with it then I am. My first thoughts were it may have been a boost error correction or lack therof but like I said you may know better then me.
aaron
This is one of those 5th grade math problems:
The Mustang reads 13.8% lower than the DynoJet numbers.
The DynoJet reads 16.0% higher than the Mustang numbers.
They're both correct and correspond to the same numbers...
Listen the fact of the matter is k.h.c has a low reading dyno and the tuner doesn't due tune his maps..Now your put in the system as a low reading mustang . We now you have 3 that are real deal low reading mustang dyno's in the evo world..Great job petey for what the car is it's a beast..
1.buschur
2.stm
3.k.h.c.
1.buschur
2.stm
3.k.h.c.
Dyno's should only be used as a tool to tune and diagnose engine performance. To truly simulate what the car does on the road an AWD Mustang Dyno with Eddy load simulation is preferred and what I only use for my Evo.
Dyno's differ. Only track times and good driving can be compared, when weight is disclosed on how a car performs differently than another.
Great info Petey!!
Please fill us in on why there's 85hp difference in hp but only 40hp difference in tq? Why doesn't the difference carry over to the peak tq output?
Also the tq curves were different from one dyno to the other? Were these both 3rd gear pulls??
Thanks for sharing your findings with the community!
1.buschur
2.stm
3.k.h.c.
1.buschur
2.stm
3.k.h.c.
Great info Petey!!
Normally its 13-15% on a properly setup Mustang (which it appears KHC has) but weather correction can play a larger factor as well. If the Mustang numbers were with differing humidity and they were uncorrected vs the Dynojet corrected there is the percentage difference.
Looking at vs speed the car didnt really make 578...it spiked right at the end when they chopped it. It would be interesting to see vs rpm and what the power was at right as it was dropping off around 84mph in that graph.
aaron
aaron
usually MD dynos read about 13% less than ours..
Mike
