Evo 8 PTE 5857 @ 31 psi on E85
Old Feb 2, 2011, 03:40 PM
  #31
sbeck0729's Avatar
[quote=Force-Fed Performance;9042716]just a fyi but i would stay away from the journal bearing billet turbos. they are known to fail. Us and about 6-7 other friends we have that own/run shops were talking about it recently and all of us have been seeing them fail.
That is good to know. The 68hta is a journal bearing billet turbo also so I guess it might be best if I go the cheaper route of a evo 3 16g if they are failing a lot. I think putting a 1400 dollar turbo on my street car is out of my price range for now although I would like to. There is an article though on the Forced Performance website about how crappy all the modern oils have become causing a lot of the newer journal bearing turbos to fail. There fix it says is to use only a dedicated race oil.
Old Jan 12, 2012, 07:59 AM
  #32
Wickedwhite8's Avatar
Did you ever get this car finished. My buddy is doing an identical setup but on a 1g. I'm just curious how you did on e85
Old Jan 12, 2012, 04:17 PM
  #33
tscompusa's Avatar
were working on it.. its on speed density now and a stroker motor. not sure what else he changed, but it should make nice power once were done.
Old Jan 13, 2012, 07:02 PM
  #34
maksim's Avatar
Your old powerband still looked impressive for a good old fitytrim
Old Jan 10, 2013, 07:32 AM
  #35
MRfastMR's Avatar
i have this turbo on a fully built. 2.4 stroker motor....lol....its fun and made 440/400 with bad compression at 25psi on 93 pump.....rebuilding the bottom end now and will be making it FF with 3" intercooler piping and some other fun bits....shooting for 500+ on 93 pump under 30psi
and the dyno was a MD
btw my comp numbers were
#1- 180
#2- 82
#3- 98
#4- 142
Old Jan 10, 2013, 02:08 PM
  #36
tscompusa's Avatar
#1- 180
#2- 82
#3- 98
#4- 142
this car was retuned by Aaron here https://www.evolutionm.net/forums/ev...e5857-e85.html and made massive hp/tq.
then he switched to a 6266 and i retuned it. he was very happy with Aaron's tune.
on the 6266 the car trapped 111mph in the 1/8 on low boost once we were done. i do not know what he did afterwords with the car, but i know he started tuning it himself now since i taught him stuff as i was tuning it and set it up so the tune was user friendly. i wouldn't be surprised if it went 9's already. he doesn't really share on forum much.
https://www.evolutionm.net/forums/ev...mph-1-8th.html
but from what i can see the 5857 is a nice turbo. it packs a lot of punch.
was your engine because of rings or something? since you had to rebuild the bottom end. i would of figured HG or valve seals or something.
Old Jan 11, 2013, 07:35 PM
  #37
veebee's Avatar
his car is insane, the engine is so nice. last i saw him, i do believe it was making at least 611awhp. not sure about torque numbers. he was rebuilding the clutch at that point, going from a twin to a triple plate.
Old Jan 12, 2013, 12:14 AM
  #38
tscompusa's Avatar
more then that. he trapped 111mph in the 1/8 with my conservative tune on the 6266 and was making 670 in vd.
its a 9 second car no doubt with driver and high boost + non conservative tuning.
with the smaller pte i believe it trapped 106 in 1/8.
that vids of it on my tune with the 6266 on a semi conservative tune.
Old Jan 14, 2013, 07:14 PM
  #39
JohnBradley's Avatar
The best I found going thru old emails was a 109 spinning violently but he was thinking it still was in the 6.30 range (no timeslips when he was at the track). He had to shift 4th to make it through the 1/8th at that point which was obviously killing the E.T./MPH
sublime44
Apr 1, 2014 09:13 AM
EVOEMS
14
Dec 11, 2012 05:05 PM
Drill_Sergeant
Jun 5, 2012 07:57 PM
Gary@MellonRacing
Sep 8, 2011 07:51 PM
Mellon Racing
Feb 9, 2010 11:59 AM
Quick Reply: Evo 8 PTE 5857 @ 31 psi on E85
