FP Black- Cosworth M2 - Aquamist HFS-6 (50/50) - 850cc FIC - Stock Block -Long Winded
Ohh, i see what you're saying. I need to drop my AFR's earlier?
And the only problem with tuning before and after meth, are those little baby injectors I'm running lol I suspect I'd run out of fuel with them before I had a antiquate map to base the meth map off of ?
I'll keep you posted. I'm tied up at work now but I'll certainly shoot you a pm when I get a chance to play with the knock sensor. Then again, I didn't touch it yet b/c i'm not interested in really making more power on the stock block daily driver I'll give it some thought this weekend lol
Did you log boost? Also like stated the tq is a bit high if you want your motor to last. I did 540hp/440tq on my E85 Red at 31.5psi for 1.5 years and never had a problem but most guys will keep tq at 400. With that being said, the later your car spools the safer high tq numbers are on the rods.
Mikey
Mikey
Mikey
Mikey
Mikey
Mikey
I didn't/don't log boost. I know i should be
A few other worrisome things: on very cold nights (such as tonight), i can almost crack 450tq. I have seen 34psi for a split second when temps drop this low (<~35*)
If i do a 4th gear pull, it easily breaks 450. With the six speed, I'm not sure how a 3rd gear pulls compares to a 3rd gear pull in a 5 speed. But i'm guessing I'm losing some tq as far as the graph goes.
The car just rips from a roll. I can put a car length on my friend's bolt-on IX almost instantly and then just keep going. I'm going to turn the boost down tomorrow though. I need the car to last ha..ha..
ya thats not true at all. id put $500 if he goes to the old dyno, his numbers would be within 1-2%.
Good job though carloverx.. just understand if it was knocking in neutral reving then theres more power in the car.
its hard to tune a car with phantom knock.. if you want help removing the false knock pm me. free of course.
I looked at the correction factor wrong.
So i was reading through this: https://www.evolutionm.net/forums/ec...-found-23.html
Anyone have any recommendations for a safe knock settings with my listed setup? As I mentioned, the car will register 6 counts of knock just free revving while sitting still. The only variables I'd like to change are the three low, mid, high multipliers and the load threshold if needed.
I'm using 88590015 for whatever it's worth. Thanks.
Carloverx
Mar 2, 2020 12:21 PM
Carloverx
Sep 9, 2010 06:05 PM
Carloverx
Aug 11, 2010 07:05 PM
scheides
10
Jul 3, 2009 08:20 AM
DynoFlash
25
Aug 27, 2007 12:00 PM
