Michael's.. 2.3L - Hta 3586 - 40+psi = Pt1
Limited by the Kelford 272's..Car needed more cam to see more power..It did pretty well for those cams however its a top end car in the end...With the bigger cam we will rev it out to around 8500rpm..Should be fine for a 2.3L
IF..the turbo can hit 50+psi..and hold somewhere close to that..and is still making power..My goal is 760whp+ on a Mustang OR 850whp+ on a DynoJet..I will dyno on both.
I will not run it at that power level..however, I would be curious to see when it was outta breath..
Clutch has never slipped from day one..its the 1st version and still doing fine especially with all that TQ..A bit noisy but I love it..Can shift like a madman..
In fact I too was curious how it would hold top end..173mph..5th gear..40psi of boost...Never slipped.
Going on 5kmiles..
very nice work man! and hopefuly u hit ur goal soon
on a side note, is that a t3 or 4 setup? u should post some more pics
out of curiosity, how noisy is it? is it like the exedy twins where its noisy upon engagment?
Ben,
Going on 5kmiles..
Going on 5kmiles..
Ben,
Going on 5kmiles..
Going on 5kmiles..
Yeah its not too bad..I mean it is noisy but im more concerned about my car being able to actually put that power down then noisy..Ben, Ill let you drive it one of these days, so you get an idea..takes some getting used too
