My 2006 IX RS VDR
#46
I'll post a pic of how my current intercooler piping is set up.. I hit a sump pump this spring and I've been tuning with a crushed flat licp haha.. sigh.. I'm dying for a cbrd ic core Fwiw...
Just wire that ***** into the ecu.. or get a uego which self calibrates and u never have to worey about your lc1 resetting.
#47
get an ets 3.5 setup, i just did some pulls tonight in 85 degrees/65% humidity and i still did 330/290 on ~24ish psi, 1st log had a single 3 count of knock, by the 4th pull it was down to a sporadic 1 count, i was pretty damn impressed.
my lc1 is in fact wired into my ecu thats the issue, and im not having the typical reset issue either, the readings are just way off in evo scan. id get a uego, but i really just dont want a blinky gauge in my face.
how are things coming along with the 11.5 hot side and FAP cover?
#53
I suspect flow is quite comparable to the white rabbit. A touch more capable in midrange but still limited to the factory turbine which is clipped.. They fp said there is a lot of debris in my turbo bearing. I hope my motor is ok.. I don't want to ruin this turbo asap so I will be cutting the filter open
#56
Turbo is on, waiting for the rest of the homebrew turbo feed line and FP intake to get here. Also, I am buying a Muse o2 dump.
Looks like the modlist will wrap up like this:
V7, ECU boost
11.5, hta71, 84FAP
Muse o2, buschur dp, magnaflow Ti catback.
FP-84mm maf tube, looking for a stock airbox aswell, to modify.
PTE 1000cc
test pipe
stock intercooler
Homebrew oil feed line with earls filter
the last of the components should be here by the end of this coming week.
V7, ECU boost
11.5, hta71, 84FAP
PTE 1000cc
test pipe
stock intercooler
