GT35R .63 on 2.0 ,91oct+meth VDyno
Old Apr 14, 2011, 09:01 AM
ramievo7's Avatar
Hi guys i would like to share with you my evo results !
here is the VD for my run :
the car has reguler gt35r 0.63 housing ,2.0l built motor and gsc s2 cams !
boost was 31psi, on 91oct+50/50 meth
let me know what do you think guys?!
happy evom
Old Apr 14, 2011, 09:40 AM
Mauricio Evo IV's Avatar
Nice!!!!! good power and spool!!!!!
Old Apr 14, 2011, 01:34 PM
RSMike's Avatar
i dont understand why everyone starts their runs so late in the rev range.
Why not start from 2000rpm?
Old Apr 14, 2011, 01:49 PM
ramievo7's Avatar
lol in this run i started @ 2500 but the logger logged from 3300 or so 1.3 is slow to start lol !
does it effect the VD calc?
Old Apr 14, 2011, 02:43 PM
ranz's Avatar
nice setup!
do you think you still have a margin to have extra power over the 529whp, since your running on 31psi and water/meth inj.
Old Apr 14, 2011, 03:02 PM
CHICKYEVO's Avatar
raise up the boost men but nice numbers for tha many pounds of boost
Old Apr 14, 2011, 07:17 PM
S13 Curtis's Avatar
Go to 100% methanol and a .82 turbine housing. I honestly think you should be making a little more power. What 35R is it? Billet wheel HTA? what size exducer 82 or 86?
Stock intake manifold If so its prolly holding you back a bit.
Nice numbers none the less
Old Apr 15, 2011, 05:49 AM
ramievo7's Avatar
the car runs stock head +stock intake mani+tb+stock uicp+stock ecu/maf+ignition
the turbo is normal gt35r .63a/r not hta i'm limited to the 91oct gas
this is run with some afr+timing tweaking !
let me know guys
Old Apr 25, 2011, 01:29 PM
bzyq2001's Avatar
very nice for 0.63, you must try .82
Old Apr 25, 2011, 01:37 PM
BEISSEN's Avatar
100% meth=wasteing money do reasearch first 50/50 is good.
Old Apr 25, 2011, 01:42 PM
ramievo7's Avatar
So far i ran 11.1 @ 130 mph with bad 60'' of 1.8
check out my drag run : http://www.youtube.com/user/brn996tt.../1/5rxMg7csCvo
let me know what do you think guys is 130mph good trap for power/setup?
Old Apr 25, 2011, 02:46 PM
project_skyline's Avatar
let me know guys
A few limitations to your setup but the power is still pretty good. AR size on the turbo is limiting your top end.
Ported head with the s2's will really open things up.
Old Apr 25, 2011, 03:38 PM
ranz's Avatar
do you believe at 31psi boost the AR will be the limitation?
i saw many threads debating about that, and it seems that at this amount of boost the effect is worthless. what do you think?
Old Apr 25, 2011, 04:20 PM
BEISSEN's Avatar
I think the larger AR will allow allot more up top as you will get more airflow and also if its the standard 35R save some extra and have FP do the HTA Houseing and it will make you think why you did not do it from the begining.
Old Apr 25, 2011, 05:24 PM
uvambo's Avatar
^ those are great numbers man, congrats.
I have a very similar set up. Standard 35r with the same .63 hot side, with stock 2.0L, on straight 92 oct (no meth) but im running a magnus, S3 cams and a ported head.
485hp ave (with a peak of 498hp)
350tq ave
All on 27psi
Quick Reply: GT35R .63 on 2.0 ,91oct+meth VDyno
