FP HTA Green, CBRD Intercooler, Magnus V5, S90 70mm tbody, Pump Gas and more!
Well guys got the car tuned on the dyno today and I'm very happy with the results.
Here is the set-up.
Perrin Filter
FP 80mm Intake
FP HTA Green Ported 18psi Wastegate
PPI Lower Intercooler Pipe
CBRD Garrett Core Intercooler
ETS Short Route upper intercooler pipe with Magnus V5 modification
Tial QR Resirc Valve
S90 70mm T-body
Magnus V5 Intake Manifold
Cosworth M2 Cams
Full-Race Pro Stock Manifold Ceramic Coated
PPI ported and Coated O2 Housing
Greddy 80mm Race Down Pipe
Tanabe Concept G Blue Exhaust
SpoolinUp New Coil on plug set-up
SPoolinUp High Z Resistor pack
FIC 1100cc High Z injectors
Perrin EBCS Pro Boost Control Soleniod
Zeitronix ZT-2 with the works
Omni 4 bar
Stock Head (Minus Cams)
Stock Block
Now some will say that the Magnus V5 may be a but much for this set-up and I
may agree. It did make my car a little lazy but right now with the stock 6-speed
transmission and stock clutch (no pill) this is not a bad thing. I also have planned
that this set-up will eventually have a Buschur 2.3 which will help with bring back
the low end grunt and a twin disc.
All and all the car feels great and Nate from TPG Tuning did a hell of a job on the tune and is a good guy to deal with on top of it all.
I also really need to thank all my friends for the help. This is the second car I've built with their help and the second to break 400whp (First was a 515whp Integra).
Just something about planning out a set-up, working your *** off to buy the parts, putting it together yourself and hitting your goals! Awesome Feeling!
The Graph (Hope to get a better one, but all I have for now)
Dyno: Mustang
Numbers: 420whp 355lb-ft
Here is the set-up.
Perrin Filter
FP 80mm Intake
S90 70mm T-body
Cosworth M2 Cams
Omni 4 bar
Stock Block
Dyno: Mustang
Dinky torque with a surprisingly late peak. Something seems not quite right. This is especially poor when you consider that it is a MIVEC and the HTA Green has always produced good torque numbers. You can't blame it all on the Magnus either. I'd like to see a boost plot.
