Evo IX + bolt ons + 93oct + tune + pics + video
Old Jun 21, 2011, 11:46 AM
gymnasty's Avatar
Hello guys and gals here are my results I made 340whp/317wtq @25.7 pounds of boost on a dynojet with the mods on my sig. I feel like I should've made more maybe like 360whp considering the mods I have, but ppl keep saying every car is different which I understand but lots of other ppl are making 360 on fewer mods than me. I know temperature and climate plays a big roll on power gains but I dont know. Im extremely happy with the way the car feels are runs but wouldve loved to see more power. What do you guys think?
Here's a dyno sheet, a pic and a vid!!
http://youtu.be/ac33Vn5Usfs <<<< sorry I dont know how to embed the video into the post
Old Jun 21, 2011, 12:40 PM
ct9asilver's Avatar
Your Injen LICP and EBAY FMIC are robbing you of power, especially if it's hot when you got tuned, those cheap cores kill hp in the heat.
Old Jun 21, 2011, 01:03 PM
90GSX-03EVO's Avatar
Yep. It's been stated over and over again that those intercoolers suck. I also agree that those Injen parts aren't doing you any good.
I'm running the factory air box, factory upper and lower intercooler piping, and a catalytic converter with an extremely limiting (in an attempt to be quiet) exhaust. I made 336 WHP and run 12.3 in the quarter mile with only 21 PSI.
Maybe I'm completely wrong. Maybe that's a low reading Dynojet. Has anyone ever heard of a low reading Dynojet?
Old Jun 21, 2011, 01:06 PM
jdmsego's Avatar
never heard of a low reading dynojet i thought they read pretty high agreed on the injen parts might have been better off with the stock pipes
Old Jun 21, 2011, 01:29 PM
06MREvo's Avatar
Originally Posted by ct9asilver
Your Injen LICP and EBAY FMIC are robbing you of power, especially if it's hot when you got tunes, those cheap cores kill hp in the heat.
^^^That & the TurboXs MBC...Pick up a Hallman Pro RX with the stiff spring...Did you do a boost leak test before the dyno session??
Old Jun 21, 2011, 06:36 PM
gymnasty's Avatar
I didn't do a leak down test but I did do a compression check a few weeks before and the numbers ran like this.
Dry: 135, 140, 150, 135
Wet: 140, 149, 157, 150
Old Jun 21, 2011, 06:49 PM
Fast_Freddie's Avatar
No bro a boost leak test... to see if you have air leaking from intercooler couplers or vacuum lines....
Old Jun 21, 2011, 06:58 PM
gymnasty's Avatar
Correct me if I'm wrong but isn't a "boost leak test" also known as a "leak down test"?
Old Jun 21, 2011, 08:33 PM
No, a leak down test is where you compress a cylinder, a boost leak test is when you compress your intercooler piping...
Old Jun 21, 2011, 09:17 PM
gymnasty's Avatar
Gotcha! Thanks for clarifying that. So I take it I should do a boost leak test and change some of those crappy parts.
Old Jun 22, 2011, 06:41 AM
06MREvo's Avatar
& boost leak test to at least 20 psi...
Old Jun 22, 2011, 09:42 AM
gymnasty's Avatar
Should I do a leak down test too considering what my compression results were?
Old Jun 22, 2011, 10:03 AM
Compression test looks good...
Old Jun 22, 2011, 12:44 PM
BubbaKush's Avatar
I would check for boost leaks, could be the reason why your car is reading low! Another could be all the cheap parts, the FMIC is not great! Next time save a few months longer and don't rush the build! Quality parts make or break your wallet, down the road they will make up for it! Good luck.......
Old Jun 22, 2011, 04:42 PM
gymnasty's Avatar
Trust me I know this. Unfortunately I'm not the original owner when I bought the car it came with that of crap of IC and ICP'ing. I'm gonna try to get a stock Evo 9 IC with the stock ICP'ing and invest on a hallman and try to tension the wastegate to help hold a pound or two more of boost.
Quick Reply: Evo IX + bolt ons + 93oct + tune + pics + video
