evo 8 tun with fp red and other mods
Hi everybody just finally got some time to post up with my new setup. tell me what you think.
mods:
K&N air filter Synapse DV Series Diverter Valve Kit BOV Injen Intake w/Upper + Lower Intercooler Pipes Greddy Cam Gears Greddy-13533301 Gates Performance Strong Timing Belt + Balance Belt HKS 272 cams Brian crower Single spring, titanium retainers Forced Performance valve stem seals Spark Tech Lancer EVO 8 Coil on Plug NON CDI System Deatschwerks 1300cc Fuel Injectors Set of 4 ARP 03-06 Mitsubishi Evolution Head Studs ARP-207-4203 Cosworth High Performance Head Gasket - Evo 4-8 4G63 86mm, 1.3mm ETS 1.50" Runner Exhaust Manifold Forced Performance Install Kit Generation 2 Forced Performance red turbo - Invidia High Flow o2 Housing Turbo Outlet ETS Test Pipe 3” down pipe and exhaust Buschur Racing Cam Sensor Heat shield Walbro Mitsubishi Evolution Fuel Pump 255 Walb_GSS342 Speed Source 2pc Under-hood Stiff Bushings Rear Strut tower bar Vac/ boost gauge Autometer Dual Steering Column Gauge Pod
i hope this helps someone elts out too. i really like this setup makes for a good dd and didn’t change my fuel economy much.
mods:
Solid #'s for the mods you got there...a few suggestions to consider would be to swap out those cams for a set of S2's, if the intercooler is stock you definitely want to get that upgraded, and also consider an O2 dump...made a huge difference on my car...just my $0.02
could keep stock interccoler for that " sleeper" look. im not sure if an evo can have that look, but bet you would suprise alot of people lol. fp red is one of my favorite turbos. good choice
FS[Northeast]: 2003 Evo, Reliable Daily Driver (Ohio)
EVO TYME!
For Sale - Cars For Sale
Oct 24, 2014 07:14 PM
motion3131
32
Jul 18, 2014 01:26 AM
