Buschur Racing-HTA3586, HTA3082, HTA3076 comparison
Old Jan 19, 2012 | 04:31 PM
  #196
tsidrift1's Avatar
Cant wait for my 2.3/hta86 combo to be up and running!!
Old Mar 21, 2012 | 11:52 AM
  #197
doubled07's Avatar
I will be going with a 76hta on my buschur 2.0L dsm motor. Thanks Dave for all the information provided here. Should be a fun street turbo for sure!
Old Mar 21, 2012 | 03:40 PM
  #198
MrLith's Avatar
Awesome, look forward to more 76HTA results- they seem like a nice unit
Old Mar 21, 2012 | 05:55 PM
  #199
David Buschur's Avatar
You are going to be happy with the turbo!
Old Mar 21, 2012 | 06:40 PM
  #200
TwStDeVo's Avatar
do you, by any chance, have any other results you can post of the hta3076r? its tougher to find numerous results like the hta3586.
Old Mar 21, 2012 | 09:07 PM
  #201
600+hp's Avatar
My old setup,
2.3 BR motor with first gen. AMS turbo kit, 50trim with .63 A/R precision turbo
HKS 272/272, stock TB and intake manifold
New setup, swapped with HTA 3076 with .82 A/R ATP housing.
some numbers, at 34lbs with intake mani swap to MAP stage 3 and BR tb, everything else is the same including the 272/272 HKS.
Fuel upgraded to ID 1000 and Walbro 400 from BR.
559whp/505wtq on a dynojet
This dyno reads the same as that of AMS which is about 7% higher than BR dyno. This Same car same setup (3076r PT) was dynoed at both places on different day of course.
Tq is dialed down a bit because of my clutch, ACT 6 pucks rated at 650 crank tq.
At 30lbs it was 51x whp/47x wtq compared to the 50trim which made 471/455
on the dynograph it was 50-100rpm slower to spool than the 50trim but the HTA run was started about 200 rpm later. If the run started at the same rpm point I'd bet it would be an identical spool characteristic as the 50 trim.
Slope of the graph is again near identical up to about 4700rpm where the 50 trim and HTA hit about 400whp. Above 4700 rpm the HTA left the 50trim in the dust.
Hoping to push it further to about 38 lbs but is currently limited by the 3.5 bar limit of the AEM. As far as the clutch I think it'll prolly hold another 50-60ft/lbs,
maybe
Old Mar 21, 2012 | 09:53 PM
  #202
TwStDeVo's Avatar
Originally Posted by 600+hp
My old setup,
maybe
nice, can you post the dynograph? just want to see how spool compares to cars with the hta3582 or hta3586. im trying to find the best turbo for pump gas (91oct) and be between 500-550whp on a dynojet. right now, it looks like the hta3582 .63 a/r might be my best option for spool and power.
Old Mar 22, 2012 | 05:43 AM
  #203
FL_SilverEvo8's Avatar
On your web site DB what turbo kit is your HTA86? Can you post the link? I dont see a listing a for an HTA86. Thanks.
Old Mar 22, 2012 | 08:46 AM
  #204
doubled07's Avatar
Between your comments and dyno results on it and speaking with Curt this turbo is gonna rock for this setup. I'll have it at the sport compact nationals in a few months as long as everything goes to plan!
Old Mar 22, 2012 | 04:17 PM
  #205
600+hp's Avatar
I can do fax. IM me fax number if you have one
Old Mar 22, 2012 | 05:03 PM
  #206
https://secure.buschurracing.com/cat...cf57a6a69edc92
Old Sep 6, 2015 | 09:27 PM
  #207
High_PSI's Avatar
Amazing read here. Thanks Dave!!!
FreakEVO
Aug 5, 2016 10:21 AM
detroit pistins
Jul 21, 2016 08:56 PM
badev0
Dec 15, 2015 06:09 AM
badev0
Oct 21, 2015 06:09 AM
badev0
Oct 13, 2015 12:39 PM
Quick Reply: Buschur Racing-HTA3586, HTA3082, HTA3076 comparison
