fp green 2.3 stroker
finally did a base run since the engine was rebuilt. Only did two runs at 25psi as we got a boost leak, hence the chart is a bit rough up top. The throttle body seals etc are leaking and i had a hose with a small split. Anyhow here is the chart, mods lited below
2.3 stroker
wiesco pistons
manley rods
2.4 crank
oem bearings
balanceshaft delete
fluid damper
ported head
hks 272's
evo green hta ported with 18psi gate
fp intake
780cc injectors and walbro 255 pump
sparktech cop
apexi power fc
profec B boost controller
water meth+ really bad 91 ish fuel
ets fmic and custom piping
ebay o2 housing
3" downpipe with 2.5 hks exhaust ( soon to be replaced with custom 3")
act prolite flywheel with street and strip clutch
will get back to the dyno soon and do some 30psi runs
The green line was the last dyno with the stock 2.0 and the evo IX turbo at 26psi
2.3 stroker
wiesco pistons
manley rods
2.4 crank
oem bearings
balanceshaft delete
fluid damper
ported head
hks 272's
fp intake
sparktech cop
apexi power fc
ebay o2 housing
as soon as get the throttle body leaks sorted out i will go back on the dyno to play. the car is a blast on the road with all the midrange torque, which is why i decided on the 2.3 with the green. I wish we had e85 here
nickelndime
Sep 19, 2017 06:49 PM
Boosted Tuning
Nov 6, 2012 03:49 PM
JMB8606
160
Aug 2, 2008 05:31 PM
