Built 2.0L/HTA3586R JohnBradley Tuned 700+whp
Old Nov 10, 2011 | 05:25 PM
Dragking2189's Avatar
After working on my car for a few months finally the car is tuned and running better than ever, I really can't be happier.. My good friend Juanito@JCF built the motor along with every single modification the car has including turbokit/fuel system etc..
I initially was debating whether to get the car tuned by a local tuner here in Miami? At the very last minute I decided to contact Aaron@EnglishRacing and it was by far the best decision I've made . Me and Aaron exchange a few emails discussing how the e-tune works , in no time I was making WOT pulls that's why Aaron is the man . we finally finished tuning the car , all I was missing was to take it to my local Dynojet. I knew the car was somewhere in the high 600's to low 700's range because on the street the car was ripping the tires from a 40 and from a 60 roll.
Last week I took the car to Machines gone wild for a quick 2 to 3 dyno pulls and the car made an awsome 715whp/585TQ @40psi. Aaron and I came to the conclusion that I should pick up larger injectors because the IDC% on my 1600's is right at 89% in 3rd gear. Finally, my goal is achieved I want to thanks every single person that may this possible thanks.
Engine/ Drivetrain
Built 2.0L 10:1 compression /Je pistons/Manley TT rods /upgrade pins/Acl bearing.
Stock head(unported) /Cosworth m3's/Supertech valves/L19 studs
Hta3586r Custom turbo kit
Exedy triple disc
Rebuilt trans with Evo8 3rd and 4th gear .
Torque solution shifter bushings
custom intercooler pipes
4" mishimoto intercooler
Buschur intake manifold
BR 65mm throttle body
3" full exhaust
mishimoto thermostat
Gates belts
Fluidampr
BR balance shaft elimination kit
Tial bov and Wastegate
Spartech c.o.p ignition
Fuel
Fullblown double pumper(modded walbro's)
Perrin fuel rail
Aeromotive Fpr -8 feed -6 retun fuel lines
Fic 1600's
stock ecu on speed density Tuned by:JohnBradley(Aaron)
More power coming soon!!!
This picture shows the 4" intake I made using 45 degree coupler ,polished aluminum tube and a 4" k&N cone filter.
Here is a video I recorded with my Iphone(quality not so good) Dynograph coming asap!!
http://youtu.be/cOx8bR003aQ
Old Nov 10, 2011 | 05:35 PM
BigT's Avatar
Excellent numbers, especially for an E-tune. Congrats! Aaron never seems to let anyone down.
Old Nov 10, 2011 | 05:39 PM
S13 Curtis's Avatar
Congrats
Old Nov 10, 2011 | 05:48 PM
Yes , Aaron is an excellent tuner he's also is very helpful and explains everything . I'm more than happy with the power the car made specially with an unported head.
Old Nov 10, 2011 | 05:51 PM
JohnBradley's Avatar
DK,
I am very happy this was able to come together so fast and be so effective. I have to admit I am always nervous about E tunes with larger injectors, especially old school 1600s. 715whp and 94-95% at 8500+ really seems to be the best we have done on 1600s, I looked at all the logs of every other 1600cc car we have had on a double pumper.
When we get some 2150s in it and run the RPM and the boost up some more I am sure there is more in it we can get
Thanks for choosing us and looking forward to more in the future.
Aaron
Old Nov 10, 2011 | 05:56 PM
ssg_petty_210's Avatar
Very nice man. Who made the manifold?
Old Nov 10, 2011 | 05:57 PM
aka.ralliart15's Avatar
Told you it was worth it Glad you're happy!!! Great work Aaron.
Old Nov 10, 2011 | 06:09 PM
Thanks Luis
Old Nov 10, 2011 | 06:29 PM
Yes, it was worth it I can't than you enough.
Old Nov 10, 2011 | 06:34 PM
The manifold was made by Juanito@jcf everyone knows him down in south florida one of the best fabricators.
Old Nov 10, 2011 | 06:44 PM
Blue91lx's Avatar
I like your setup
Excellent numbers BTW.
Old Nov 10, 2011 | 06:50 PM
pls1968's Avatar
Wow awesome numbers. Easy 9's man. Hope you bring it out to the next event.
Old Nov 10, 2011 | 06:57 PM
Thanks pete, I will be there next event for sure . I hope your car is up and runing asap.
Old Nov 10, 2011 | 06:59 PM
Originally Posted by Blue91lx
I like your setup
Thanks man, like your setup as well
EvoJoeIX's Avatar
Wow great power man
Quick Reply: Built 2.0L/HTA3586R JohnBradley Tuned 700+whp
