I just don't understand the gamble, if you're gonna push 500+ then why not play it safe? Failures at that level can be catastrophic and cost more to repair than if it was built. Awesome stuff though, you got ***** I'll give you that.
600+ Stock block checking in....
Its also still going solid. Not to mention i just installed a Full Blown 70mm TB today upgraded from stock. Should be good for a few more horses
A good tune is all you guys need.
he was spilling oil out of the block, so there is likely a window now.
OP, did you lean out on that pull?
when i had the fuel pump housing issue i was really carefull with the car and monitoring the afr's.. we fixed it but i guess we didnt totally did it right.
i did some pulls with it earlier with afr's around 11.6-11.8 on e85
at the time when it went kaboom i was watching the boost gauge and didnt pay attention with the afr gauge.
