Built 2.0 6262
Old Mar 24, 2012 | 09:37 AM
s.e.a.n.'s Avatar
Built 2.0 6262
Here is a VD graph at 32lbs
Basic run down of the setup.
Built 2.0
Stock head
CP 10:1 Pistons
Race Eng Billet Steel Rods
FP4r cams
Supertech springs and retainers
Full blown double pumper(2 walbro intake)
FIC2150
Tial Q
Custom 3" IC Pipes
ETS 4in intercooler
Fabworx T3 manifold
DBB 6262
Exedy Triple Disk
Old Mar 24, 2012 | 10:11 AM
05ah8james's Avatar
is this on 93 pump?
Old Mar 24, 2012 | 10:36 AM
gsrboi80's Avatar
Gotta watch those VD graphs when they spike up at the end of a pull like that. It'll inflate your numbers a bit. Not that numbers mean **** but you get the idea
Old Mar 24, 2012 | 11:07 AM
s.e.a.n.'s Avatar
Originally Posted by 05ah8james
is this on 93 pump?
This was on E85!
Old Mar 24, 2012 | 11:18 AM
Boosted Tuning's Avatar
+1
That spike isnt suppose to be there.
Your car is making like 585-590, not over 600.
Old Mar 24, 2012 | 04:58 PM
s.e.a.n.'s Avatar
Originally Posted by Boosted Tuning
+1
I'm no VD guru but the car will hit a dyno jet soon.
Old Mar 24, 2012 | 05:03 PM
tscompusa's Avatar
hes right.. the graph is inflated at the end.. use the rpm trim tool and remove it.. the fact that anomaly exists at the end though i would trash the entire graph and just redo the run over again.
Old Mar 24, 2012 | 08:03 PM
evane's Avatar
Nice...how far can you push that 6262?
I dynoed 593/464 on a dyno jet. Stock block, 6262, e85
evane - Mellon Tuned Evo 8 dyno pull
I wanna see a 6262 pushed to in limits curious to see how much it could make on 40psi
Old Mar 25, 2012 | 06:42 AM
s.e.a.n.'s Avatar
That's very good power for stock block. Do you have stock ignition? Once I get an ignition I'll turn it up to 40lbs!
Old Mar 25, 2012 | 08:09 AM
Nomad4g63's Avatar
very nice SEAN
Old Mar 25, 2012 | 08:19 AM
jonzie04's Avatar
nice results! if you don't mind a little soldering, you can pick up a DIY spoolinup kit, source some coils and come out at around $200. There are also DIY COP threads here but I'm unsure of how well they work.
Old Mar 25, 2012 | 10:47 AM
evane's Avatar
Yeah stock ignition.
Old Mar 25, 2012 | 03:15 PM
phrequenc's Avatar
Looks good dude
Old Mar 29, 2012 | 06:23 AM
Steeldon's Avatar
+1
Yet he still claims it..
Corn Fed
Built 2.0 6262
615/469
Old Mar 29, 2012 | 06:28 AM
Evofiebre11's Avatar
Corn Fed
Built 2.0 6262
615/469
IM on no ones side here, but So what if he is claiming im almost positive that with a lil more/better tuning lil more boost which block can deff handle this car make around 650whp if not more on a Dynojet
Quick Reply: Built 2.0 6262
