Pte 6466 T4 803whp/559 tq. Comparison between 6265 & 6466 also!
#43
I can certainly see why Scott would opt for minimum waste gate springs in a safe fail safe boost range. Most people don't recognize that for a waste gate boost drop safeguard feature to work, minimum waste gate pressure has to be in a safe range with ECU controlled boost to work. I would leave the springs alone for a while until you get used to it and then maybe add like 3psi stronger combo that should support +6psi in boost control range on top.
Now you are making me have to go back to the Dyno and make 805whp lol!
LOL 805!! I see how it is..... turn the wick up on urs already.
![Big Grin](https://www.evolutionm.net/forums/images/smilies/biggrin.gif)
